Old 04-28-2012   #1
Daniel_Mc
Daniel_Mc's Avatar
Default After plenum pull....
I have pulled the plenum, IH's, rebuilt the TB, and pulled the cam covers. The Z started right up idles fine and drove good until you hit 3K rpm then it feels like you are hitting the rev limiter? I pulled the plenum back off thinking I didn't plug something in but it's all plugged in. Also it is throwing code #56 - Vacum sensor circuit? So what am I missing or what did I goof up?
Thanks,
Daniel
Daniel_Mc is offline   Reply With Quote
Old 04-28-2012   #2
Default Re: After plenum pull....
MAP sensor under ECM plugged in?
Old 04-28-2012   #3
oricale
Your secondary system is not right either vacuum or electric...I pulled my secondaries and the chip wasn't set right and I had the same issue.
Just a thought
oricale is offline   Reply With Quote
Old 04-28-2012   #4
Daniel_Mc
Daniel_Mc's Avatar
Thanks Lee that was it! I'm a dumbass....
Daniel
Old 04-29-2012   #5
Blue Flame Restorations
Daniel, I would be relieved to be a dumbass in that situation! Simple fix.
See you in a couple of weeks!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-29-2012   #6
CJ_ZR1
Daniel
Truth is out! First step is admitting it...
CJ_ZR1 is offline   Reply With Quote
Old 04-29-2012   #7
Daniel_Mc
Daniel_Mc's Avatar
Absolutely! I was thinking the worst and never trust my work so when I saw the plug I was relieved! (after some choice words of course...)
Now I "think" I'm ready for BG! See you then!!
Daniel
Old 04-29-2012   #8
Daniel_Mc
Daniel_Mc's Avatar
You have no room to talk ****h! LOL thanks for all the help.
Old 04-29-2012   #9
cward
cward's Avatar
I need to make a test post. Hope you don't mind my using your thread.
Curtis
cward is offline   Reply With Quote
Old 05-01-2012   #10
tf95ZR1
tf95ZR1's Avatar
Curtis
Welcome back Curtis!
