Old 04-17-2012   #1
Default dyno numbers / upgrades done
we are trying to compile a list of members and upgrades, with dyno #'s.
Please post up your real RWHP numbers with upgrades you have done.
Mine:
1994 Stock bottom end
422 RWHP Heads / Cams / Headers / Ported Top End
Soon... I will give my car back to Pete to finish tuning
Old 04-17-2012   #2
sammy
Default Re: dyno numbers / upgrades done
1990 with 180 k miles . jeal headers 21/2 in dr gas exhaust with spin tech mufflers , fidanza flywheel and stage 3 clutch . ram air air cleaner ,410 gears ,corey henderson ported inj housings and plenum , as well as one of coreys dyno tunes . 409.9 rwhp and 373.6 tq.. that dybo run was with a flowmaster set up . best et corrected 11.58 @ 123.11 mph .
Old 04-18-2012   #3
efnfast
To the best of my knowledge, stock except for K&N in stock box. 1990, 40K. Just dyno'd at 311. OBX headers and exhaust go on tommorow. As soon as I spring for a Marc chip I'll dyno again.
Steve
Old 04-18-2012   #4
Steve
Steve
Let us know how the header / exhaust install goes!!!!!
Old 04-18-2012   #5
efnfast
You know I will David, I'm giddy to get it installed. The headers were at Swain Tech for a month.
Old 04-18-2012   #6
My mods - see below... Future mods being considered:
63mm TB
electric water pump
Dyanamax muffs
(Hoping these get me closer to 445-450 ish at the wheels w/o compromising drivabilty.)
P.
Old 04-18-2012   #7
SteelBlueZR1
1991 with 6k miles, Marc's chip, Open lid air cleaner with K&N, otherwise all stock just dyno'd at 321 hp and 323 tq.
Old 04-18-2012   #8
gunman0
gunman0's Avatar
1991 with 78k miles.
Doug Rippie chip
Corsa Cat-back
K&N Filter
343 RWHP/337 RWTQ
91 Black ZR1
DRM Chip
Corsa cat-back
gunman0 is offline   Reply With Quote
Old 04-18-2012   #9
RHanselman
RHanselman's Avatar
1991 16k miles
613.19 RWHP
576.97 RWTQ
Raptor Twin Turbo @ 8 psi (engine built for 15 psi)
Raptor 374 CID 9:1 comp
Stock crank rods and CAMs
Custom Pistons
Head Studs
Jeal Headers
R/T CATs
Up graded fuel system
Mark Haibeck and Corey Henderson Tune
RHanselman is offline   Reply With Quote
Old 04-18-2012   #10
RHanselman
RHanselman's Avatar
1993 Ruby with 40k miles
532 CHP 452 TQ
Jeal 368, 12:1 Comp
J&E forged pistions, file fit plasma moly rings
Eagle ESP I beam rods
Clevite 77 race bearings
Blueprint and balance
Full Port
Titanium retainers
EA22H intake CAMs
Stock Exhaust CAMs custom timing
Siamese Plenum
63MM TB
Ceramic coated Watson Headers
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
