Old 04-24-2006   #1
TMORROW
Default Water Pump.
New to Forum, thank God you guys are here. I think I need a water pump for my 1990, any thoughts? Also how hard is it to remove?
TMORROW is offline   Reply With Quote
Old 04-24-2006   #2
Default Re: Water Pump.
There is one on E-Bay.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 04-26-2006   #3
It’s not to bad…if you don’t have a Shop Manuel make a template you don't want mix up the bolts, as they are different lengths
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-26-2006   #4
Z Factor
Z Factor's Avatar
Hello and welcome to the forum.
You may want to take a look through this section for many helpful tips on maintenance and repair.
http://www.zr1netregistry.com/ZR1_howto.htm
Old 04-26-2006   #5
1990 quasar blue
I did mine last fall and it wasn't that bad. John Sullivan here on the forum has them at a good price. I'll try to find you his email address.
Here it is john.sullivan@protective.com
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 05-01-2006   #6
TMORROW
Its definitely the water pump, had to drain the water level until I could feel the bearing was bad. All the bolts came out with out a problem except for the small vertical one. Still working on that one. I was looking through the archives here and found one about a heads up display, there is one for the ZR1, when I get it I will post a photo with more details. Thanks for the help and this site.
Old 05-02-2006   #7
carter200
carter200's Avatar
Welcome Hope your pump replacement goes smooth. These guys are great at helping when your are about to pull your hair out. Take care and enjoy your ride
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
