![]() Join Date: Jul 2005
I would appreciate some help...
1. Is our ECM case the same as any of the LT1' cases? 2. What are the part numbers for the 4 ECM connectors in the case? 3. Are the individual connectors for our ECM case the same as any LT1? 4. Are these connectors still available? And yes, I have a ECM project... I'm also looking for a bad ECM that I can use for parts... Cheers, Ron Last edited by RHanselman; 03-27-2012 at 09:27 PM. |
![]() Join Date: Jan 2009
Ron,
EFI Connection can hook you up with the connectors and pins. I can't link directly to it, but go to this link: http://www.eficonnection.com/eficonn...torSearch.aspx and then select 22 cavities, all colors and all genders. The connectors will come up. Order one of each and the appropriate terminals and you are good to go. Warning, it will lighten your wallet a bit! Jep |
The LT1 ECM is in an entirely different case (aluminum body). However, the L98 ECM appears very similar externally. I believe that's the '727 ECM.
Andrew
#4 | |
Thanks... |
I think those aluminum cased ones are only in the '94-'96 LT1 cars. The '92-'93 cars have the same case as the ZR-1. I used to have a '93 LT1 and the ECM looked the same as the one in my '90 Z.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
Ahh, good to know!
#7 | |
![]() Join Date: Jul 2007
the connectors on the 90-91 L98 and 92-93 LT1 will work the ECMs share the SAME PCB connectors if I am not mistaken.. I have 2 of the 7727s which could work for parts for your project. However, the internals are different.
The LT5 ECM's are a much thicker case than the L98/LT1
[SIZE=3][B][COLOR=Red]Worlds largest ZR-1 LT5 Parts Store[/COLOR][/B][/SIZE] [URL="http://whiteracingproducts.com/"]http://whiteracingproducts.com[/URL] New & Used Parts, as well as free Locator services. [EMAIL="sales@whiteracingproducts.com"]sales@whiteracingproducts.com[/EMAIL] (813) 264-6368 |
#9 |
![]() ![]() ![]() Join Date: May 2007
Hmm did not know that Im sure Cliff did however.
#10 |
Did the MY 94 and MY 95 ZR-1 get the aluminum ECM covers like the LT1 and LT4 received later in 96. Or did all Zs stay with the same plastic ECM?
