03-18-2012 | #1 |
Carpet Adhesive.
Okay everyone I am going to try and get the Dynapad, Dynamat and Avic Z140 installed before bowling green.
I got the stereo, Bose adapter and antenna extension from Dennis@ doubleD mods. I am thinking of adding a sub and amp. Would this affect the sound from the Bose Speakers? What would you use to re-glue the carpet down?
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
03-18-2012 | #2 |
Re: Carpet Adhesive.
Did you get your Avic Z140 yet?
I've also been thinking of installing a Nav... (and the dynamat btw...) |
03-18-2012 | #3 |
Not to change your topic but do you know of a sill plate that looks good and are any count? See ya at BG ....
03-18-2012 | #4 |
re-gluing carpet where?
03-18-2012 | #5 | |
03-18-2012 | #6 |
With the Dynamat and Dynapad wont I need to use some sort of adhesive?
03-18-2012 | #7 |
dynamat has a sticky backing.. I don't know about dynapad \
but the 3M spray adhesive works well
03-19-2012 | #8 |
I've done 4 cars now in total - not claiming any expertise - but I've found two adhesives that are my "go to" glues, depending on the application requirements:
3M spray-on adhesive (black can) for large areas requiring less adhesion, or areas that might need to be removed again later. The sills area comes to mind, or sticking down the cargo floor area for another. Liquid contact (brush-on) cement (Mid America's carpet adhesive is good chit) for areas needing high-strength such as locations where the carpet is stretched over curves, or along trim edges, pieces hung on vertical or nearly vertical surfaces (e.g., the center console sides) or in the footwell and knee pad and kick panel areas. I find limited use for the spray on adhesive, far as gluing carpet goes. It goes on quickly, carpet can more easily be removed later where the spray is used, and there is the limitation: strength. I prefer the liquid stuff if it reeeeaaaally needs to stay put, even if it is a chore to remove later. Just my 2 cents... P.
