02-26-2012 | #1 |
Bringing THUMPER Back To Life PROJECT
Well, I've threatened to do this since last Fall. The time $$$$$ has finally come to make it happen. This is the year to make the car mechanically sound. Once that is accomplished, the cosmetics will begin.
Background The car is a 1990 #702. It's a no-hit 40k mile car from Georgia. Sounds nice, huh? Well, the kid that had it blew a head gasket or something and decided he would make a bracket car out of it. He took a really nice Z and just absolutely killed it!!!!! He stripped this thing as clean as you can get under the hood, ripped the gages apart, removed every bit of the fuel and brake systems....everything. The car is Blk/Blk and God aweful UGLY at this point. I bought the car for $3500 with no drivetrain and alot of missing parts. I've bought just about all of the parts needed to put it back on the road. I only need a few more parts and probably a small fortune of little incidentals. We'll see. I also bought Dominic's wrecked 92 and a 92 LT5. The LT5 will be used for this car. "PETE" of FBI and Sauage fame is doing the major mechanical work for me and I will handle the rest. You might ask if I'm a glutton for punishment of just plain nuts????? Well, a little of both. I enjoy "the build" more than driving them. But I want a driver that I can enjoy my way, so I'm about to venture into ZR-1 Day Camp. The laundry list of mods is as follows: * ZR-1 Convertible Conversion * Brake Upgrade with Stainless Lines * Headers * 4:10's * Hurst Short Throw Shifter * Port/Polish Top End (no heads at this time) * Custom Chip and Tune * Coils and Injectors * Trans Rebuild * Powder Coat Engine * Powder Coat Dymag GenII's Argent Silver color 17x11 Front, 17x13 Rear * Tires 315's Fronts, 345's Rear * 1996 Style Sport Seats * Upgrade Radiator * FBI Free Flow Flapper Exhaust (center exit)......eventually. OBX for now. * Euro Tail Lamp Kit * Own Design Body Enhancements * Jet Stream Blue Paint work As the project progresses, I'll update this thread like I did the UK Graveyard 88 EX5023 Prototype thread. I hope everyone enjoys watching the car's restoration and modification. Here's a few pictures of THUMPER now, as the UGLY Z.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 02-29-2012 at 10:24 PM. |
02-26-2012 | #2 |
Re: Bringing THUMPER Back To Life PROJECT
Wow, looks like you've got your work cut out for you.
02-26-2012 | #3 |
Thanks for letting us follow along. When done I bet it will be gorgeous.
02-27-2012 | #4 |
Cool, I love following restore threads. After finishing my own long restore project, I know the amount of work it takes to finish them.
I'll be looking forward to the updates, especially the convertible conversion part.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
02-27-2012 | #5 |
Holy smokes Brett! Now that's what I call a kit car!
subscribed! I have to watch this ZR-1 being born again! Tom
02-28-2012 | #6 |
Well, the cleaning started on the LT5 today. It's not
TOO bad but does have some thick grime in places. Mostly the sides and around the oil fitting area. What's the best cleaner to remove the grease? What has everyone had good results with. Cleaning processes??? Testimonials???
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 03-10-2012 at 05:49 PM. |
02-28-2012 | #7 |
Ordered and/or bought a bunch of parts so far.
OBX Exhaust - Just using it until I build a center exit FBI unit. Coils Injectors Brake lines under the car (they were taken off) Braided Stainless Flex Brake Lines Oil Pressure Switch Coolant Hoses Upper Alternator bracket Alternator Water Pump C5 Front Calipers and C4 Rear Calipers Trans Parts for rebuild NOS Console Door OBX Headers AC Lines Brake Booster Master Cylinder Clutch Slave Cylinder Throttle Cable ECM ECM bracket Long Wheel Studs for 13" wheels Fuel Tank
02-28-2012 | #8 |
so we can count on you coming up with lots of NLA parts for our cars then?
jesus what a fuster cluck
02-28-2012 | #9 |
I use spray brake cleaner by the case, with a short bristle paint prush ans some of the disposable ss wire brushes about the size of a tooth brush.
02-28-2012 | #10 |
So... Done by BG this year?
