Old 02-26-2012   #1
Default Porous Heads repairs
Porting heads can be a sticky situation.....repairs often do not seal...check this out...I brought this up before, using vacuum to pull a sealant into the weld..apparently loctite has a product and process for this.
http://www.henkel-loctite-kid.de/en/...S_brochure.pdf
Old 02-26-2012   #2
Default Re: Porous Heads repairs
Yep!
I had some pinhole leaks following a repair on one of my heads. The leak was opposite the valve spring seat where the runner gets very thin. I couldn't pull up the pdf file (long story) so I'm not sure which LockTite was being used to make the repair. However, I used some LockTite that Marc recommended, applied vacuum to the runner to draw the goop in until I could see little beads of the stuff coming through the pinholes. I let it cure 24 hours and re-applied the vacuum and tested for leaks with soapy water. NO leaks.
That was a couple seasons ago, and upon inspection last fall, still no leaks.
Bob G tried to use the same stuff, but for some reason couldn't get it to set set up. (Bad batch or something???) It never would harden - just remained liquid even over night . So, he ended up using some type of aviation-grade aluminum-impregnated epoxy and massaged it into the pores and then sanded the runner smooth. Seems to have done the job!
P.
Old 02-26-2012   #3
Also reading an article on welding....guy flooded the coolant area and runners with Argon to get good results
Old 02-26-2012   #4
Yes. This allow the gas shoud on the tig welder probe to be removed. That makes it a lot easier to get int tight spots and do a good job, i'm told.
I understand too that the rod material selection is critically important. (I can tell ya that Marc's guy 's welds were glass-smooth and form fitting to the runner shape. This made for very easy touchup)
P.
Old 02-27-2012   #5
rhipsher
rhipsher's Avatar
Even good sand castings have porosity in them. Investment castings are better but more expensive.
