Old 02-05-2012   #1
Route 66
Route 66's Avatar
Default Fast Idle
I just started my car after replacing all the injectors. Started it an let it come up to temp. It idles ok but too high of RPM. Idles at 1100. Any one know what I might have done wrong. I thought I would check here first before takeing it apart again.. Thanks..E..
Route 66 is offline   Reply With Quote
Old 02-05-2012   #2
Default Re: Fast Idle
Cheack your map sensor hose on the back side the plenuim. It prob came off
Old 02-06-2012   #3
Possibly may need to reset IAC.
Old 02-06-2012   #4
Route 66
Route 66's Avatar
Thanks for your help. I will check that tomorrow. I feel sure I put it on. Sometime back that hose came off when the motor backfired an it had a miss. That isn;t happening now it runs smooth. But I will check it.............Thank You..E
Old 02-06-2012   #5
Route 66
Route 66's Avatar
How do I do that..E
Old 02-06-2012   #6
Other possibilities ...
http://www.zr1.net/forum/showthread.php?t=11753
Vac leaks and hose next to the front of the plenum behind the air horn may have popped off
Old 02-06-2012   #7
Route 66
Route 66's Avatar
I would like to thank all of you for your help with this. Goldcylon your link was the most helpful. Thanks for taking the time to look it up. It has given me a number of things to look at. Although I think I will be pulling the plenum. I think I now know where the leak will be. I never thought about it being a vacuum leak. I was thinking electrical....Thanks Again..E
Old 02-06-2012   #8
bdw18_123
I had a high idle problem too after I got my Z back together. Mine was higher at like 3K rpm though. Turned out that my TPS was not adjusted correctly.
So you might also want to check that your TPS (throttle position sensor) is properly calibrated. There is a procedure in the service manual that outlines how to check and adjust it.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 02-06-2012   #9
Route 66
Route 66's Avatar
Thanks..I will look into that if what I found today doesn;t fix it. I took the plinum back off today. I found one of the larger plastic tubes was loose. I glued it back in. Tomorrow I will put it back togather an I will try again. I will read about the TPS tonight incase I have to go there........ Thanks E.
Old 02-06-2012   #10
If you can a clamp or ziptie can work wonders keeping these little buffers in place
