Old 01-25-2012   #1
Paul in VA
Default Electric water pump for the LT5?
Hi Everyone:
Would an electric water pump installation be possible on an LT5? Would it help solve the over 5000 RPM cavitation and lack of cooling at extended high RPMs? Any thoughts are welcome...
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 01-25-2012   #2
VetteMed
Default Re: Electric water pump for the LT5?
my understanding is that the higher rpm lack of cooling is dependent on the flow through the radiator, hence the "bypass" tube in the cooling system. I was under the impression that the pump that Lotus spec'd for the LT5 was capable of far more flow than the GM-spec'd radiator was capable of managing.
I've never seen an electric pump for the LT5...
Old 01-25-2012   #3
Pete has been using one for several years.
Old 01-25-2012   #4
Originally Posted by Paul in VA View Post
Hi Everyone:
Pete, Kevin, and I believe possibly Al and maybe Bob G are using 'lectrics.
As I recall, Pete said he estimates approx 7-12 hp can be gained at WOT by making the switch to the electric; definately on my wish list...
Must be an FBI thing. It's a secret, so doan chew tell nobody, heaha?
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-25-2012   #5
Must be. Ok guys spill the details
Old 01-25-2012   #6
VetteMed
wow, news to me... they've been pretty hush-hush about it, I guess.
Old 01-25-2012   #7
Pete
Pete's Avatar
I have been using ELectric Water Pump for about 4 years.
It's been working great for me.
I use a Stewart 55 GPM pump.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-28-2012   #8
HAWAIIZR-1's Avatar
I do remember Pete did shared info about this a few years ago. Sounds like a great tech article for the HOTB and another secret how to achieve low 11s on a 350. Pete you are like an Einstein for the LT5!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-28-2012   #9
Hib Halverson
Pete....when you ran an .04 and an .09, what was the air like?
What tire did you use on the back?
What's your axle?
What's the car weigh?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-29-2012   #10
Pete
Pete's Avatar
I don't know what the DA was on those days from what i can remember temps were either low 40's or low 50's, i never look at the DA when i go racing,the day at BG from what i remember was 80 maybe somebody that was at BG that year can refresh my memory and post up.
Drag Radials with stock front wheels/tire size.
What's your axle?
11.04 & 11.09 passes were with stock rear gears 3.45
The Bowling Green run was with 4.10's
I have done all the weight savings mentioned in Marc H's. site plus a few of my own i.e.94-95 door penals,sliders for stock seats etc. last time i checked she was about the same as C6 ZO6.
And....what is your shift point rpm?
Peak HP is 6800,shift light is set at 7200
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Tags
electric water pump
