Old 03-28-2006   #1
frank12
frank12's Avatar
Default Line faster with less spinning
Fastest car = lower tire pressure
To that pressure can decrease the wheels
without the tire skates?
(I mean: interior of the tire, being able to him to damage it)
Frank Teixido
Barcelona/Spain
Member 451
AM.C.C.C.
frank12 is offline   Reply With Quote
Old 03-28-2006   #2
Aurora40
Aurora40's Avatar
Default Re: Line faster with less spinning
Do you mean for everyday driving? Or specifically at the dragstrip?
You can also boost the pressures in the front tires to reduce their rolling resistance, but you'd probably only want to do that in a straight line.
Old 03-29-2006   #3
frank12
frank12's Avatar
For dragstrip.
I suppose that to reduce the pressure a lot, it could cause that the tire of the interior part of the wheel skated and to damage the tire.
(It would break the valve of entrance of air)
Frank
AM.C.C.C.
Old 03-29-2006   #4
Aurora40
Aurora40's Avatar
I'm no expert, but I'd think if you kept 20-25psi in the tire it wouldn't spin on the rim or have the rim dig into it.
Old 03-31-2006   #5
blackjack
the trick here is to deflate the rear tires just enough to have a full contact patch on the asphalt...if the center of the patch is lighter in color than the rest,your tires are too soft...if the edge is lighter,your tires are too hard...you have to do a couple of burn-outs to adjust
blackjack
91/1735
