Old 12-31-2011   #1
rhipsher
rhipsher's Avatar
Default Just a routine oil change.
So I do the usual. Drain it then dump it down the toilet and flush it. "JUST KIDDING" then go one place to pick up 9 quarts of Amsoil. Then advanced auto to get the filter cuz the first guy sells the oil but no filters. So I walk into advanced auto and I notice a tire track on the floor. So I ask did somebody lay some rubber on your floor? And the salesman says know. Somebody drove into the store. He said some kid getting stupid flew right off the main street and took out both double doors and three racks. I said you've got to be kidding. I said that must of woke you up. They were there when it happened. Yikes.
Old 12-31-2011   #2
efnfast
Default Re: Just a routine oil change.
Can't wait to see that on "Worlds Dumbest"
Old 12-31-2011   #3
The kid probably thought it was a drive through part's store....(Boooooo)
Old 12-31-2011   #4
mike100
there's a 7-11 on the corner that had a car smash into it twice in the last 10 years.
The streets don't intersect at right angles so if you forget to turn 20 degrees to the left- into the store you go.
