Old 12-13-2011   #1
Socalerv
Default Gojacks
Has anyone used or owns a set of Gojacks? Thinking of buying a set to help me move the cars around in the garage for more space.
I have seen different styles of wheel jack/dollies in the past. Want a product that is robust and easy to use.
I have been told you can keep the car on the dollies for extended periods of time without any damge to the tires, I do not know if this is factual or just a sales pitch.
Any first hand information is greatly appreciated.
Socalerv is offline   Reply With Quote
Old 07-22-2012   #2
Socalerv
Default Re: Gojacks
I tried this once before and recieved no feedback so I will try again.
My wife wants her parking spot back in the garage so I need to pull the Z in and then push it as close to the wall as possible. Think that these gojacks would do the trick.
Does anyone use them?
Can you leave the car on them for weeks at a time?
Erv Myers
1990 ZR1 #1964
Old 07-22-2012   #3
VetteMed
Default Re: Gojacks
Erv, tires are pretty tough, and I don't think it'd cause permanent damage to leave the car on these for a while. Tires can deform from sitting in one position for a while, and the Gojacks might accelerate that, but to how significant a degree, who knows? Never tried these myself, so I'm speaking purely on conjecture.
Old 07-22-2012   #4
WVZR-1
Default Re: Gojacks
Go-Jack by brand is a quality product. They'll do just what you want them to do. You'll be surprised at how effortlessly! You want to find a local vendor that does wrecker/roll-back/dolly supplies and parts. Most of them probably do Go-Jack by brand or a product that's it's equal. Price? I would think a "local" if asked might "price-match". I'd try to stay with the Go-Jack by brand.
You might be able to get a "test" before purchase from a "local"!
I've a friend that uses them and cars stay on them for weeks. Is it wise? Don't know. I don't know that most Go-jacks have a brake on them so you might need to lower a pair of wheels to put the tire on the ground to keep the car situated.
Old 07-22-2012   #5
zrwhat
zrwhat's Avatar
Default Re: Gojacks
I have a set made by OTC and seem like a quality product, I'm able to store 3 cars in a 2 car garage by using the go jacks. Some have the poly or plastic wheels but are harder to move, steel wheels seem to work the best.
Do a google search before you buy, lots of information and feedback available to help you with your decision.
Gibby
zrwhat is offline   Reply With Quote
Old 07-22-2012   #6
tpr60
Default Re: Gojacks
Be carefull with the width of the rollers. I tried using them on my ZR1 rear tires and they are not wide enough to release and get the low jacks back out from under the tires. Had to use a floor jack. Test drive first!!
tpr60 is offline   Reply With Quote
Old 07-22-2012   #7
WVZR-1
Default Re: Gojacks
There's models I believe that will do 13" but you're right you need to "test drive" or "check"! I suggested in my first post - "TRY LOCAL"!! It pays to shop "LOCAL"! This is or would be a convincing example!
Old 07-23-2012   #8
rbidwell
Default Re: Gojacks
I have a set of skates that I left my 69 on for several months and saw no damage to the tires. They allowed me to put 3 cars in my 2 car garage.
Ron
If life is just a highway, then the soul is just a car. meatloaf
rbidwell is offline   Reply With Quote
Old 07-23-2012   #9
Socalerv
Default Re: Gojacks
I will try to locate a pair to try on the rear tires, somewhat a test drive. If they work it has solved a large problem for me.
Thanks for all the input.
Erv Myers
1990 ZR1 #1964
Old 07-26-2012   #10
zrwhat
zrwhat's Avatar
Default Re: Gojacks
As stated in my post, I have a set of OTC Go-Jacks and they fit my 335 30 18 tires just fine....
