![]() Join Date: Mar 2007
Did a plenum for someone.....they went to 63mm TB so they asked me to open up the Plenum to TB and Air Horn.......
Besides moving to 63MM I went in and smoothed out the all the trasitions some ported and unported pics: Unported ![]() Ported ![]() Unported ![]() Ported ![]()
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 12-12-2011 at 09:54 PM. |
![]() ![]() Join Date: Feb 2010
LOTS OF WORK!
Nice work Lee. How much does that run?
I threw it in with the port job....
![]() Join Date: Dec 2004
uoooooh smooooooth !
![]() nice flow ya got there mister! ![]()
![]() Join Date: Jan 2007
Was that increase to 63mm just for the porting. I know Aaron Scott stopped putting 63m throttle bodies on his portings because the HP gain was near zero. Did I miss something here?
This person needed a rebuild due to an issue so he upgraded through someone......I just followed up on the request...its worth a few HP...smoothing should help...I was a skeptic, but a Mercury smoothing the airhorn actually showed a modst increase. They apparently had an engine on the dyno and did step by step mods for HP
![]() Join Date: Feb 2011
I kind of wonder at what hp level the 63mm throttle body is beneficial. I guess you might get a couple of hp from smoothing the sharp edges on a stocker- maybe, but I'd have to think you might benefit on a 500 hp engine more.
Has anybody done much testing on different combos? |
#9 |
i remember reading, maybe incorrectly, that the pirate car didn't have any gains from a 63mm tb
#10 |
![]() ![]() Join Date: Nov 2007
Transitioning the edges won't hurt, for sure. But, it seems to be quite abrupt still.
A topic for an FBI pizza night: I've been pondering something with a smoother and less abrupt transition; more in keeping with the 4% guideline (some use) for port transitioning. What I envision is more along the lines of a pair of internal funnel-like tubes. They would extend from the "big" ports and merge along a knife edge and morph to fill the shape of the horn at the inlet oval. Borrowing a term from another discipline, "impedance matching" is the goal: The less abrupt the change, the better for flow. OK, it isn't an original idea. If you get a chance to look into the rectangle inlet of a supersonic fighter e.g., an F-15 or the like, and you'll see what I'm talking about. My point is, "bumps" in the air stream, like rocks on the bottom of a shallow stream of water, cause pressure waves that extend way beyond the shape of the intrusion. Concept: ![]() I have no idea if it would be worth the trouble to build, but it might be something to experiment with. Just a thought. P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-14-2011 at 06:37 AM. |
