Old 03-21-2006   #1
BBBAD94ZR1
BBBAD94ZR1's Avatar
Talking MY NEW BNB SYSTEM INSTALLED
Take a look, http://www.corvettevalley.com/galler...ry.php?cat=552, got it put on today, cat back with x pipe. It sounds awesome, it will rattle the fillings in your mouth. Now the car sounds as bad *** as it looks.http://www.corvettevalley.com/galler...ry.php?cat=552
RAY
[FONT=Century Gothic][SIZE=5][COLOR=black][I]:dancing[/I][/COLOR][/SIZE][/FONT]
BBBAD94ZR1 is offline   Reply With Quote
Old 03-21-2006   #2
Z Factor
Z Factor's Avatar
Cool Re: MY NEW BNB SYSTEM INSTALLED
Looks great
Old 03-21-2006   #3
Aurora40
Aurora40's Avatar
Default Re: MY NEW BNB SYSTEM INSTALLED
Are those the standard tips? Or different ones? It looks great!
Bob Saveland
Former owner of #2517
Old 03-21-2006   #4
BBBAD94ZR1
BBBAD94ZR1's Avatar
Not the standard tips, I ordered them this way, I did'nt care for the oval tips.
Thanks
RAY
Old 03-22-2006   #5
Sweeeeet looking exhaust, Ray!
How's the drone(resonance) in 6th @ less than 2k rpm?
How difficult was it to install? Sorry for the Q's I'm just making a list for the future.
Old 03-22-2006   #6
BBBAD94ZR1
BBBAD94ZR1's Avatar
Easy to install less than an hour, hardest part was getting the mufflers lined up. The car in 6th under 2 k will rattle your teeth. You can hear it 1/4 mile away.
Ray
Old 03-22-2006   #7
moesvette
moesvette's Avatar
Hey Ray. Looks nice. I put mine on my 90 several months ago......group purchase at TByrne. I did resonator instead of X pipe hoping for less resonance, but got plenty at highway speed anyway. I have had a tough time keeping the tips from twisting out of alignment though. I have cranked down on the clamps until I twisted one bolt off, and B & B sent me another right out. They suggested tack welding to eliminate the slip. Not crazy about that, but will if there are no other options. You have any problems with that?
1990 Red/Tan Mark Haibeck Chip/B & B
moesvette is offline   Reply With Quote
Old 03-22-2006   #8
BBBAD94ZR1
BBBAD94ZR1's Avatar
Talking Re: MY NEW BNB SYSTEM INSTALLED
I had my tips welded on at BNB when I ordered it.
Thanks
RAY
Old 03-22-2006   #9
moesvette
moesvette's Avatar
I should have been more specific, sorry. Not the tips actually that is the problem, it is the first joint in front of the mufflers that is clamped. The pipe actually slips and twists some which causes that whole tail end section of muffler and tip assy. to twist out of parallel. Looks bad. B & B suggested tack welding at the pipe joint to prevent that.
Old 03-22-2006   #10
4DSZR1
4DSZR1's Avatar
I Have B & B's on mine and they twisted also, the problem is the crummy clamps they use I put these on and BINGO the problem went away. You wont be sorry, and you dont have to weld.
http://www.jegs.com/webapp/wcs/store...1527&langId=-1
4DSZR1 is offline   Reply With Quote
