Old 11-30-2011   #1
avijay
Default Injector Failure Signs?
What are some tell tale signs that your injectors / coils are going bad? I have a 91 and it surely doesn't feel right on acceleration and has a little bit of a shuttering on acceleration. I assume it's time to change the injectors, coils, plugs, wires, etc but just want to make sure I'm trouble shooting the right thing.
1970 LT-1 - sold
1971 Vert - sold
1972 454 - sold
1996 Grand Sport - sold
1999 C5 - sold
1969 Mustang Mach1 - sold
1991 ZR-1 - sold
2008 Z06 - current
avijay is offline   Reply With Quote
Old 11-30-2011   #2
Kevin
Kevin's Avatar
Default Re: Injector Failure Signs?
well your car is a 91...so you can assume they're bad. when they first start going bad your car will start to run rich before it goes lean then you'll get a knock when the car is warm. you can also ohm them...12.5-15 ohms is what you want
my injectors are bad and while i'm in there in the spring i'm going to do air filter, injectors, wires and plugs
Old 11-30-2011   #3
tccrab
tccrab's Avatar
Remember, there are 16 injectors, two separate systems that integrate on full acceleration.
The symptoms will differ depending on what combination of injectors are going bad and the condition of the "failure", i.e., injector stuck open, injector stuck closed, or simply an injector with bad spray pattern.
Lots of combos to think about.
A primary injector stuck closed or with a bad spray pattern will cause a lean condition with a rough idle and sympathetic dual mass flywheel knock.
A primary injector stuck open will cause a fuel rich condition and the spark plug will eventually carbon up and cause misfires.
Multiple bad primaries will cause rough idle, stumbling on regular (non-secondary) acceleration, dual mass flywheel knock, and if bad enough the ECM will set a SES light because the O2 sensors will read high or low depending on the condition.
Bad secondaries in a closed condition, i.e. fuel lean condition, will cause stumbling on secondary acceleration initiation and significant leaning of the engine at high rpm and O2 sensors reading high.
Bad secondaries in an open condition will cause stumbling on secondary initiation and smooth out as the airflow leans the a/f mixture to optimal.
Mix up the failures and all kinds of good things can happen.
My advice is to replace the fuel injectors, the spark plugs, and while you're underneath the plenum check the coils and replace as necessary.
Just my $0.02
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 12-01-2011   #4
oricale
Thats exactly what Im doing...AMMMOOUUNNGG.....other things!!!!
1990 ZR1 #00077 (10Y022 PEP CAR)
1991 ZR1 #00517 ("Irene")SOLD:cry:
1992 ZR1 BLACK RED(2016
2009 Z06!! BLK/BLK rare Linen interior 707HP!!
2006 BLK/BLK Z51 (Just SICK FAST!)SOLD)
1996 BLK/BLK LT4 Grnsprt(sold...Twice!)
1991 RED/REDL98(Fell off the shipping truck:(
1980 BLK/RED L82(Sold)
1990 RED/BLK( sold.....In Japan)
2006 Mustang GT mach 1(sold)
1969 Mach(sold in Japan)
1969 Mach 1#2(sold)
WAZOO Member...
www.evolution-motorsport.com
facebook/evolutionmotorsportengineering
Your Local [url]www.Amsoil.com[/url] dealer/user..
*Victory Loves Preparation*
oricale is offline   Reply With Quote
Old 12-01-2011   #5
Use a spark tester, the inline kind to test for coil output or use a DVOM. Please resist the impulse to pull off plug wires while at idle as our Ignition brain boxes, aka the DIS module, doesn't react well at all to that treatment.
You can ohm out the coil + it's wire pair using the two plug ends of the wires, but if you have to go under the plenum the "while we're here" rule comes into play.
If a primary injector goes south from the alcohol in the fuel it will mimic a dead miss. The alcohol shorts the coil and no fuel to that cylinder. You'll get the Dual Mass rattle like Tom said. Also, if you have a scanner you can see the results of the lean mixture by looking at O2, BLM's and Integ numbers. Or, you can use your nose. If she's lean enough you can smell it....trust me! The miss will not go away. Also, it may not miss on cold start, as the coil heats uo the miss will become more pronounced. Also the plug(s) for those cylinders where the injector coils are bad will look like no gas is being delivered.
Old 12-01-2011   #6
carmine
I Recomend RC Injectors And Jerrys Gaskets Carmine #357 Black Gray Stock
carmine is offline   Reply With Quote
Old 12-01-2011   #7
Hib Halverson
You can remove all 16 and test their coils.
You also can have an injector specialist, like RC Engineering, test them for flow and spray pattern.
But, if your injectors are original, ie 20 years old, I'd just pull 'em out and replace them with RC Engineering units.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-02-2011   #8
ZR1Vette
ZR1Vette's Avatar
Are the RC injectors the ones that have to be modified by removing a small tab on the injector?? Or was that for Accel injectors?
Edit- added this pic showing the tab removal so can you ID that the injectors are RC or Accel from the pic?
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 12-02-2011   #9
RC's are plug and play. I'm not 100% on the Accels, I think you have to do the grind to get our harness plugs to plug in to the coil terminal...not 100% sure though
Old 12-02-2011   #10
FIC have stainless steel injectors and look like OEM
http://fuelinjectorconnection.com/shop/
Speak with John. He also carries Jerry's gaskets, so you can get everything at once
We have installed many local Z's with these...
