11-09-2011 | #1 |
FS: Pressure plates
I have 2 used pressure plates for sale. All parts are located in Houston, Tx.
1. Centerforce pressure plate - less than 16k miles, good condition. $75 +shipping +paypal fees. 2. Factory ZR-1 pressure plate - from a 94 ZR-1 with approximately 35k miles on it, good condition. $50 +shipping +paypal fees. Aaron |
11-10-2011 | #2 |
Re: FS: Pressure plates
Why did you take them off?
11-10-2011 | #3 |
The Centerforce pressure plate was taken off when it was discovered that the clutch disc was bad. My wife bought me a new pressure plate and clutch disc as a present. So that went on instead of just replacing the disc.
I got the factory pressue plate when I purchased some other parts from a member. This pressure plate was taken off when a fidanza aluminum flywheel swap was done. |
11-10-2011 | #4 |
Any chance you can tell which one is lighter?
Thanks, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
11-10-2011 | #5 |
batchman - they both weigh a little over 16 lbs. If there is a difference it is less than 1/2 lb.
Aaron |
