11-07-2011 | #1 |
FS: Fuel Injectors and Rear Hub/Bearing assemblies
I have the following items for sale...
All items are located in Houston, Tx. 1. Full set of 16 used fuel injectors, 8 primary and 8 secondary, from a 93 ZR-1. These were working when they were removed from the car. They would most likely need to be cleaned to work their best. Asking $225 + shipping +paypal fees 2. Bearings have been SOLD! Aaron Last edited by ammrpm; 11-09-2011 at 10:58 PM. |
11-08-2011 | #2 |
Re: FS: Fuel Injectors and Rear Hub/Bearing assemblies
Aaron,
Interested in the bearings. I'm assuming they accommodate ABS? |
11-08-2011 | #3 |
XfireZ51 - I assume they will work just fine with ABS. They were bought for a 95 corvette that had ABS as well. I did not put these on that car though, so I am not 100% sure.
11-08-2011 | #4 |
Basically the bearings have a "strobe wheel" as part of them so the ABS sensor, attached to the hub, can read it. I'll PM u on them.
11-08-2011 | #5 |
ABS sensor is seperate on the rear hubs.
It installs on the suspension knuckle and sinses speed from the gear wheel pressed on the axle spindle.
11-08-2011 | #6 |
Phil - thanks for the pictures and explanation.
11-08-2011 | #7 |
Yes, thx Phil.
11-09-2011 | #8 |
