Old 10-30-2011   #1
Customvetteguy
Default F/S 1995 ZR-1 #234 34 Miles
1995 ZR-1 #234, 34 Miles, Brand New, Black on Black. The car has never been titled. It has both tops and Dunn heads. The car has just been serviced including oil change and injectors. I even put an original pf70c oil filter back on the car. I replaced the Windshield on the car with a KW windshield cause the car was perfect except for some bad delamination on the original windshield. Original windshield goes with the car. This car is perfect for someones collection or someone who just wants a brand new 1995 ZR-1. Car is for sale on ebay item# 110768218999 $59,999. I can ship Worldwide.
Thanks, Ryan
(330)-819-5029
Customvetteguy is offline   Reply With Quote
Old 11-09-2011   #2
Customvetteguy
Default Re: F/S 1995 ZR-1 #234 34 Miles
Car will be at Barret Jackson in Scottsdale Jan 2012.
Old 11-09-2011   #3
ZONER 95
Its a beauty....I'll be watching it.....Good luck with the sale.......Kevin
95 ZR-1 #178
Black/Beige
Dunn Heads
ZONER 95 is offline   Reply With Quote
Old 11-09-2011   #4
MikeGolf
Less than what the original price was. But it does have a replacement windshield on it. Is the air in the tires original?
'93 #166 Black Rose
“Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” Heraclitus
MikeGolf is offline   Reply With Quote
Old 11-09-2011   #5
cvette98pacecar
Thanks, Ryan
(330)-819-5029
Im curious as how a car with 34 miles has a delam windshield where it needs to be replaced.
Old 11-09-2011   #6
1990 415
Mileage has no influence on delamination. Later windshields were worse for delamination.
1990 415 is offline   Reply With Quote
Old 11-09-2011   #7
PhillipsLT5
PhillipsLT5's Avatar
If you are selling at B/J I hope you have a reserve
I know it has been a no reserve auction in the past, but recently they have been allowing at a higher % reserve cars, these cars probably also will not get prime time slots, Good Luck
Old 11-10-2011   #8
Kevin
Kevin's Avatar
it's long been my belief that the lack of sunlight on the windshield causes delamination
Old 11-10-2011   #9
cvette98pacecar
The windows delaminate because of the heat that is created between the exterior piece of glass and the inner aluminum sheet. the heat actually causes the aluminum sheet of foil to separate for the glass. Guessing that this Vehicle has been stored for most of its life it did not see the light of day. So where did the heat come from?
Old 11-10-2011   #10
Customvetteguy
Car was in Climate controlled storage all its life. I have had a few of these cars that have been stored in climate controlled garages all their life and doesnt matter how the car is stored. You either get a little Delamination or a lot. Car was originally bought by a collector and just stored in with his other Corvettes. The guy got ill and started to sell off some of his cars. Even 1995 ZR-1 #448 in the Corvette museum is delaminating pretty bad to. It's the luck of the draw. Anymore Brainbusters?
