Old 10-16-2011   #1
Chappy
Default Part Identifications
I picked up a few ZR1 parts a while back, in the box were a couple of parts I can't identify, can anyone help?
This looks to be an oil pump driveshaft, but I didn't think LT5s had a normal shaft like this. Maybe a distributor drive?
Obviously it is a pedal for either the clutch or brake, I just don't know which. Any ideas?
I also got a rear brembo brake kit, anyone know who might have made it or any information on it? It has a parking brake included in the hub, so it definitely isn't a normal C4 kit.
Thanks in advance!
Chappy is offline   Reply With Quote
Old 10-17-2011   #2
Default Re: Part Identifications
Looks like a custom kit allowing the parking brake to be retained however using Brembo calipers
Old 10-17-2011   #3
A1990
A1990's Avatar
I agree with Daryll
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 10-17-2011   #4
Also for pre-90 MY cars prob 86-89. Not ZR-1 specific unless its a mule ZR-1 narrow body etc
Old 10-17-2011   #5
no, 89 is same as 90
That pedal is a clutch pedal
Old 10-17-2011   #6
Chappy
Thanks guys, appreciate the help. Didn't realize there was a change in parking brake between years on C4s.
Old 10-17-2011   #7
VetteVet
VetteVet's Avatar
I agree with Jeff on the parking brake setup. Not custom, just 88 and prior C4 setup.
The shaft is an oil pump drive shaft from a Chevy Pushrod V engine. Could be V-6 or small block V8 or big block V8.
Jep
Old 10-17-2011   #8
VetteVet
VetteVet's Avatar
Sorry, Make that 87 and prior. My Bad!!!
Old 10-20-2011   #9
gbrtng
gbrtng's Avatar
The clutch pedal might be from a certain twin-turbo ZR-1 that was converted to an automatic. Just guessing.
Old 10-20-2011   #10
Bob Eyres
There was also a non- turbo ZR-1 in your Indy area converted to Automatic.
