Old 10-10-2011   #1
Corbusa
Default best anti-freeze ?
I need to get ready for winter , so what is a really good anti-freeze? I'd like to keep the system clean and hope to never change the heater core etc. IS Amsoil anti-freeze good ? What about Napa Cool or water wetter ? Thanks Guys !
Old 10-10-2011   #2
mike100
Default Re: best anti-freeze ?
For the LT5 you need to use the old fashioned regular non-long life coolant. I used the basic autozone jug and some 15 year old Prestone I still had. The good news is that it's cheaper than the long life/low tox stuff.
Old 10-10-2011   #3
Plain old generic Green stuff. Dont use anything else
Old 10-10-2011   #4
mike100
pretty sure the 'Solutions' sticky has a good listing of commonly available coolants.
Old 10-12-2011   #5
Barnds are all over the map but just make sure ITS NOT DEXCOOL!
Old 10-12-2011   #6
Hammer
Hammer's Avatar
Talking Re: best anti-freeze ?
Napa Auto has the green antifreeze needed. The jug will state on it "contains silicates".
Old 10-12-2011   #7
ittlfly
Correct. It is the 'Napa" brand in a blue jug. On the back you will see it meets GM -1825M spec for our cars.
ittlfly is offline   Reply With Quote
Old 10-12-2011   #8
Dime
Zerex is also very good.
Dime is offline   Reply With Quote
Old 10-12-2011   #9
Aurora40
Aurora40's Avatar
Just FYI, but Prestone does not make an EG coolant anymore that is suitable for the LT5. So don't pick up any coolant in Wal-Mart or similar, as that's all they generally have. The NAPA green stuff is good. Also a GM dealer will have the right stuff, though it now costs a fortune ($30 a gallon last time I checked).
Water-wetter is apparently similar to DexCool, but it really isn't an anti-freeze. As it is mainly water, it would freeze pretty easily. I think they even recommend you add anti-freeze with it if you use the A/C, as it can freeze in the heater core.
I've personally used the low-tox stuff with no problems. The additives are the same, it is still a silicated coolant just like the OEM stuff, but a PG coolant vs EG.
Old 10-13-2011   #10
Just a reminder about the GM stuff you now buy at the parts counter.....it's not a silicated coolant any longer. It's a H-OAT coolant. They kept the same part number on the new coolant and they kept the same "GM spec 1825-M", but it is an organic acid coolant.
I ran into this when I bought some from a local dealer up here this past April.
Some chevy stores have some of the old original stuff laying around. I got some from what used to be P&G Chevy in PA.
Just read the label on any GM coolant you get from the chevy store very carefully before leaving the parts cage.
