Old 10-07-2011   #1
Blue Flame Restorations
Default LT5 NO EMMISIONS
I see the LT5 in street rods with no apparent emissions canisters or anything coming off the engine. Since I'm in IN and we have no inspections, and I'm piecing this drivetrain together, I'd like to leave all of this stuff off the car. It's missing anyway.
What do I need to do to run without the emmisions stuff? Burn a chip or????
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-07-2011   #2
Kevin
Kevin's Avatar
Default Re: LT5 NO EMMISIONS
i'd contact mark or pete
Old 10-07-2011   #3
ittlfly
You are going to have a chip burnt from Marc or??? Since you are not installing the emmsisions the ECM will be commanding systems 'on' and may throw a code??? ie: ECM canster purge selonid 'on' by supplying a ground.. I'd sure give Marc a call.
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 10-08-2011   #4
Thanks
I hope to maybe see Marc at the drag strip Sunday.
Old 10-08-2011   #5
I installed SW Headers, SW Exhaust, Eliminated the Air induction, Eliminated the Secondaries, Eliminated Secondary Vacuum system, Eliminated Throttle Body coolant. Marc created two chips (87 Octane, and 91 Octane)
http://www.zr1.net/forum/showthread.php?t=15690
Oh...almost forgot...also have Locobob's (Robert) Head, Injector Housing and Plenum Porting, and Pete's reground Camshafts with new Mellings JB 2236 lifters.
And....Ronald Woods LT5X Studs
As well as Jerry's new Head Gaskets which are a bit thinner
And....some other stuff like relocated Dual Oil Filters to prevent oil Drain Back
Is that all?????? Sounds like a good grocery list!
Old 10-08-2011   #6
Did you use both I/E reground cams? 500hp? Is that rw and did you measure on dyno?
Brett,
Things like Charcoal canister and DFCO, can be disabled in the cal. I do that when tuning so they don't muddle the results. After I have the VE and Spark set, I turn them back on and fine tune from there.
Old 10-08-2011   #7
YES on cams....expected Flywheel hp.... and NO on Dyno......engine is still out of the Z pending further considerations untill Dec
Also using Marc chip in L98
L98 gets very Close to 100 mph in quarter from some testing between cornfields down the street. Have to watch out for combines and tractors
Craig,
Thanks. I was curious since I'll be taking
mine to do some dyno tuning at end of the week.
BTW, my Xfire would get close to 105mph at the end
of the 1/4.
Old 10-08-2011   #8
Here is the LT5 grocery list for ya
(1991 ZR1 with (LT5))
I have another L98 grocery list also.
500 horsepower
New starter installed
I elected to NOT drill new drain hole under starter
(I will blow drain tube clean with compressed air from underneath from time to time)
New Ron Davis radiator
New 180 deg thermostat
New Water pump
New Red Samco hoses
New Zerex Original 1825 on label antifreeze
New Stainless powder coated cross over pipe
New Randy Woods Aluminum power steering pump pulley
New Randy Woods Aluminum water pump pulley
New Randy Woods LT5X Head Studs
New TB and Plenum coolant elimination
New Belt Tensioner
New Serpentine Belt
New Jeffvette braided stainless steel oil cooler lines
New 200 amp alternator
New Front cover oil seal
New Crankshaft rear oil seal housing gasket
New Primary timing chain
New Primary timing chain guide
New coils
New LT5 plug wires
New plugs NGK Iridium BKR5EIX
New LH chain tension
New RH chain tension (new style)
New Jeffvette Billet aluminum Camshaft hold down clamps
New Mellings JB 2236 Lifters
New Elite Oil catch can
New RC SL4-205 injectors on fuel rails with new "O" rings
New SW headers ZR1CORVOR
New SW exhaust ZR1CHAMSW
New brake pads in C5 Z06 calipers
New Center Force pressure plate
New Center Force unsprung clutch plate
New Throwout bearing
New C4 Beam Plates
New Differential oil drain plug (drilled and tapped)
New Mobile 1 75W-90 Differential oil (limited slip)
New Mobil 1 M1-207 Oil filter
New Amsoil 10W-40 AMO Engine oil
New Castrol TWS 10W-60 Transmission oil
New Billet Aluminum oil cap
New Chrome Dip Stick Tube by LT5-1935
New 91' Brass key chain (GOLDCYLON provided)
New LED tail/brake lights (48 LED per light)
New Billet aluminum tail light louvers
New LED CHMSL lights (6 LED per bulb)
Eliminated Secondary actuators
Eliminated Secondary vacuum system
Eliminated Throttle body coolant
Eliminated Air Induction system
Eliminated CATS
Upgraded Powder coated air horn
Upgraded Powder coated throttle body
Upgraded Engraved throttle body
Upgraded Cam timing 114In 108Ex
Upgraded Powder coated plenum
Upgraded Powder coated injector housings
Upgraded Powder coated coolant manifolds
Upgraded Engraved coolant manifolds
Upgraded Ported injector housings/plenum (Locobob)
Upgraded Ported heads/injector housing (Locobob)
Upgraded Ported Air Intake (Locobob)
Upgraded Regrind Intake Camshaft Intake .236 .425 (Pete)
Upgraded Regrind Exhaust Camshaft Exhaust .220 .425 (Pete)
Upgraded Valves reconditioned
Upgraded Wilwood two piece rotors turned/painted
Upgraded C5 Z06 calipers and Wilwood two piece rotors
Upgraded C5 Z06 calipers repainted
upgraded Bose radio/CD player
upgraded Door amplifyers
Like New Red hard top from my 90 L98
Modified Marc Haibeck chips
....87 octane calibration.
....OE spark timing 23 + 6 = 29 degs. @ 4400 rpm. 25 + 3 = 28 degs. @ 5000 rpm.
....Enabled manual transmission.
....Both fans to go on at 205 and both off at 200 degs (180 deg thermostat).
....Fuel added to support +100 HP.
....Anti-backfire mode enabled.
....CAGS (1 to 4 shift) disabled.
....Power key mode default is ON.
....91 octane calibration.
....Fuel added to support +125 HP.
....Knock retard reduced by 50%.
1991 #1427
Kinda makes me dizzy...............and also envious
Old 10-08-2011   #9
Brett,
Thanks, Dom. I'm going to install all of the emmisions on the 88 but not on the 90 and 92. The 90 is almost ready to send to Pete. Been working on the plumbing. That kid raped this car of everything extra. No fuel ines, brake lines, fuel tank, booster, slave cylinder, etc. Stripped pretty clean. I have almost everything gathered up and installed now. It's a very straight and solid car though. Only has 40k miles. Clean as a whistle underneath, too. It'll make a very good driver/waxer Callaway kit daily driver.
Now, I just need to collect some parts for the 92.
I NEED AC LINES from the compressor to the evaporator box.
