![]() Join Date: Aug 2008
My Samco hose kit came with one short straight hose and honesty I don't see where it goes. And don't remember pulling one off like that. Im in the middle of put it back together.
One end connects to the bottom of radiator and then the other end connects to the Thermostat housing. Installation tip. Install on the bottom of radiator first then to the top of the thermostat housing
THEN... connect the top of the thermostat housing to the body of the TH unit. It wont go on any other way as its very short like the original. GC
Ah yes I see it now. Can't see it from the top. I never took it off that's why I didn't remember it. The trick to getting the big hose on that goes from the water pump to the TH junction is to connect it to the water pump first then maneuver the water pump in place without snapping the oil sensor off and your good to go. During this I've found that im missing two fan mounting screws on the passenger side fan motor and one missing on the drivers side.
#4 | |
I saved this job till my radiator pull a few years ago.
Or when the water pump goes out like me.
Not trying to be a smart a$$ here but ..ya think!!!! I've had to R&R mine twice and without pulling the plenum each time due to a bad diode and then a bad bearing on the rebuild. It ain't a lot of fun. There will never be an easier time than at the stage where you are now.
#7 | |
Actually thats what happened to me. A water pump turned into a well while your there replace the radiator project and hoses. lol
Just a couple tips:
#9 | |
#10 |
Those are the hoses all right. Thanks for posting.
