Old 09-13-2011   #1
ZRapid-1
Default Car Preparation for Track Event
Hello all,
I am taking my 90 Z to a HPDE at Lime Rock Park next week. Am looking for helpful advice as to car setup and preparation.
I have just replaced the brake fluid with DOT 4. There is no air in the system and the pedal is firm.
The car has new Michelin Pilot Sport PS2 tires (335/35ZR17 on rears). Will bring a compressor and add a few pounds at the track to stiffen the sidewalls.
I have read that the front corner air deflectors should be removed to allow more airflow for front brake cooling. Looks like three bolts holding on each side.
Obvious stuff like making sure the Full Engine Power switch is on, air conditioning is turned off, and radio is off.
Anything else?
Thanks in advance.
ZRapid-1 is offline   Reply With Quote
Old 09-13-2011   #2
Mr Cool
Default Re: Car Preparation for Track Event
I don't really have anything C4 specific to add but that's pretty cool. I've pondered taking my wifes 90 to the track just to try it out if she would let me. I think before I did that I would give the brake system A good work out on a little used road just to see how long it would take to start to see brake fade. I think that would be my biggest concern. I think your gonna be removing air, those tires are gonna heat up fast with that heavy car. I would start 32 cold and and check it after your first session. I really would like to hear your comments after the event.
If this is your first event you may want to reconsider a crack habit would be alot cheaper.
________
90 white/grey #2011
Mr Cool is offline   Reply With Quote
Old 09-14-2011   #3
Do you have the pizza box? I ask because in it is the ZR-1 owner's manual and it has a section devoted to HPDE's. It has a good amount of info on prep and even some driving tips.
Also, not to be a wise guy, on that other forum there is a section just for road racing. If you log on to their index page after the C1 & C2 forum you will find the "auto cross and road racing" forum.
Good luck, keep her out of the tall grass!
Yea, I've heard that most drugs like Heroine, cocaine & crack & meth are less expensive habits.....
you need a pit crew?
Old 09-14-2011   #4
Mr Cool
I agrre the Autocross Roadracing forum In CF is a good source. Also setup next to other corvette drivers, in the southeast a bunch of us setup together and help each other out or just bs.
________
90 white/grey #2011
Old 09-14-2011   #5
Originally Posted by ZeeAreOne View Post
Anything else?Thanks in advance.
Coilovers?
Old 09-14-2011   #6
lbszr
lbszr's Avatar
Sounds like you already did the most important with flushing the brake fluid. What fluid did you use?
Even if your wheel bearings are tight now, I'd have a spare. Sometimes they only last a day, depending on the brand. I drove mine to the track the first time, blew a front bearing, luckily somebody there had a loaner.
What pads are you running? Spare rotors are good.
I ran mine with the outer air dams off also until installing brake ducts. I don't know if it helped.
As mentioned, 32 psi is probably the most, cause when they get hot the pressure will be about 40 and above that most tires turn to grease. But that pressure will probably help the tire shoulder when the alignment is stock. But less pressure if you want traction.
Keep an eye on the engine oil level. Mine uses about .25 of a quart in 1000 miles on the street. But on the track it uses .25 in 30 minutes. Oil catch can would really be good.
Have fun! As mentioned, I'm thinking crack probably would be the cheaper route though.
Here's a lot of good car setups.
http://www.cardomain.com/ride/418999...rolet-corvette
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 09-14-2011   #7
jrtoffroad
As mentioned look at your brake pads, I highly recommend HAWK or Cryotech. At my first event I had a set of auto part store pads BADLY glaze and chunk, damaging the rotors.
Be sure you're running high temp brake fluid. I'm using Wilwood 600+, but there are a number of good options. My first event was at a course that is hard on brakes and I had problems boiling the valvoline synthetic I'd just put in.
As lbszr mentioned, start a little low on tire pressure, it will come way up. The front will gain more pressure than the rear. I usually shoot for 36 to 38psi hot as a starting point on the track then tweak from there.
You could also tweak your alignment adding some negative camber for improved traction and more even tire wear at the track.
jrtoffroad is offline   Reply With Quote
Old 09-14-2011   #8
Mystic ZR-1
Mystic ZR-1's Avatar
I tracked my '89 L98 C4 @ Lime Rock about 8 years ago. You'll find that the stock brakes suck after the 1st lap when your slowing from 125+ to about 60 for "Big Bend"... Hawk pads would help. Your wheels will be black from the brake dust. I used the 37/37 psi in the tires, but this may not be the optimal. The main thing is to try to be smooth, you'll feel it in your butt when you get the corner "right". The trick is to get all the corners "right", which comes only with practice (I never came close... I gave up thinking I was cut out to be F1 World Champion that day). My best effort was a 1:08 on a "flyer" that I couldn't ever duplicate, most laps were in the 1:10 to 1:13 range (on the "old" course, no chicane or new corner). I put almost 80 track miles, in several 20 minute sessions, on my car that day, and boy does it use up gas while you're doing this!!! Guaranteed you'll "pucker" cresting the top of hill at the end of "No Name" straight, the car gets VERY light, the wall is VERY close and it's a slight turn to boot... suggest you stay straight and turn late after the cars settles. The downhill turn leading to the main straight is deceptive too.
Save setting "a neeeew track record" for your next visit, concentrate on trying to get it right. Good luck and have FUN!!! Remember, all bets are off with your insurance company while you're doing this...
Doug
Old 09-14-2011   #9
DaveK
Install the painted roof - it adds rigidity.
Dave
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 09-14-2011   #10
PhillipsLT5
PhillipsLT5's Avatar
Mystic really has it wired
Full tank gas, partial tank will slosh and push car in corners
