Old 08-17-2011   #1
gbmidyear66
Default Dyno'd my 90 Today
I wanted to get a baseline on my car before doing anything further. The car to my knowledge is stock with the exception of a Flowmaster Cat back exhaust and a revised prom (prom was intended to fix idle and CAGS). Despite what the legend says - I am assured that the values are RWT and RWHP.
What could I expect with a good top end port (which is what I am thinking planning) - close to 400?
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
gbmidyear66 is offline   Reply With Quote
Old 08-17-2011   #2
bobbyhi
bobbyhi's Avatar
Default Re: Dyno'd my 90 Today
My '90 with top end ported and headers put down 399.78 rwhp. Also has the the K & N air filter.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 08-17-2011   #3
My 92 put down 399/357tq with top end, Watson 1 7/8" headers and Magnaflow cat back including resonator. We found later that the cams were out of phase Left/Right.
Old 08-17-2011   #4
At the crank with headers Yes. To the rear it will be real close.
Old 08-17-2011   #5
Jim Nolan
My '92 dyno'd at 398 rwhp and 358 torque, with top end porting, corsa, no cats & headers.
Old 08-17-2011   #6
Nacho_ZR1
Those are excellent numbers for the mods you have. Mine dynoed at 342 RWHP when it was stock. With Jeal headerss, X-pipe, no cats, I got to 375 at the wheels. I'm sure a good port job would get you close. Good luck!
[B][U]---SOLD BUT NOT FORGOTTEN---[/U][/B]
[SIZE="1"][SIZE="2"]1992 ZR-1 #483
[COLOR="DarkRed"]Dark Red Metallic[/COLOR]
[U][B]Mods[/B][/U]
-Jeal headers
-Stock exhaust with X-pipe
-4.30 Gears
-Corey Henderson tune
-375 RWHP[/SIZE][/SIZE]
Nacho_ZR1 is offline   Reply With Quote
Old 08-17-2011   #7
gbmidyear66
Thanks guys.
I guess I was a bit optimistic. Without headers (prefer to avoid the the additional noise) I'll probably end up closer to 385.
Will have to track down a good port & polish guru this winter.....
[SIGPIC][/SIGPIC]
NCRS BC Chapter
Old 08-17-2011   #8
Thanks guys.
Surprisingly, the headers don't add noise. I was pleasantly pleased when I installed my Watsons. Interesting how close these numbers are across different top end ports ( did my own)and headers.
Old 08-17-2011   #9
391rwhp...without a tune....headers and Borla with X pipe....and a spare plenum thats ported and ready for install!
Old 08-18-2011   #10
Nacho_ZR1
Just noticed you are in Vancouver? I was there 3 weeks ago and am due back in September..I'm doing some IT work for Fortis BC over in Surrey. Maybe we can grab a pint? I'll send you a PM. Oh and if you DO decide on headers, please do yourself a favor and get them Ceramic coated and header wrapped. Mine are ceramic coated but there is alot of heat that seeps up through the console. Makes my car almost impossible to drive in summer...
[U][B]Mods[/B][/U]
-Jeal headers
-4.30 Gears
