Old 08-10-2011   #1
mgbrv8
Default auxiliary fan
I want to run some pusher fans or fan on my condenser. What size is optimal for a front mount fan on a 91 Zr1.
Dave
Old 08-10-2011   #2
secondchance
Default Re: auxiliary fan
Another option I cinsidered was a same diameter but higher CFM fan to replace one or both factory fans. Additional amperage may be a concern on wiring.
Keep us posted.
Old 08-10-2011   #3
A few years ago I was going to put some SPAL fans offered by Madvet via Fluidine or one of the other all Aluminum radiator mfrs outt here if I remember correctly. They put out more CFMs of air movement and were a direct wire replacement for the orginal fans. However they didnt fit like the factory fans and required a pair of spreader bars to mount to the radiator. Due to this I sent them back. Oh yeah no instructions came with the either.
