Old 02-28-2006   #1
ZR1 MK
Default aluminum flywheel and bolts
He are some pictures to show and clarify the Fidanza flywheel and mounting bolts. I used 1 1/4" grade 8 flywheel to crank bolts and zr1products.com (Specialized Racing Products) pressure plate to flywheel bolts (ARP 200,00 psi). The stock flywheel to crank bolts are too long to use in the aluminum flywheel and the stock pressure plate to flywheel bolts are too short for the aluminum flywheel.
Keep in mind, all grade 8 bolts are not created equal. There are lower quality grade 8 bolts, probably from China, that are equal to USA made grade 5 bolts. Know your sources.
The Grade 8 flywheel to crank bolts I used are fine for typical usage. High power cars and extreme usage can benefit by using ARP 230-7303 bolts. ARP doent classify there bolts into grades, but rather psi rating. A grade 8 bolt is in the 150,000 psi range, where by, the ARP 230-7303 is a 200,000 psi bolt. Its considerably stronger. I will be using the ARP 230-7303 bolts when I get my higher power engine installed later in the year.
ZR1 MK is offline   Reply With Quote
Old 02-28-2006   #2
Default Re: aluminum flywheel and bolts
Thanks Mike! We really appreciate you sharing these detailed pics and info.
Old 03-07-2006   #3
ZR1 MK
Glad to help.
I included more info on the bolts since I got more questions by email throught the Net Listserv.
Old 03-26-2006   #4
I'm with Craig! Thanks a bunch for sharing the knowledge!
