Old 02-23-2006   #1
TommyL
Default Need Help With Brake Pads...What to Buy??
What would be the best choice (brand and type) of brake pads for the Z if one was putting new drilled and slotted rotors on all four corners?.
The car is only used on the street and I would be concerned not only about performance, but low brake dust as well.
I have seen "Satisfied" brake pads advertised alot...anyone use these?
TommyL is offline   Reply With Quote
Old 02-24-2006   #2
Bill
Bill's Avatar
Default Re: Need Help With Brake Pads...What to Buy??
I put Bosch ceramic pads on mine about a year ago (7K miles). I have been very pleased with them. Like you all of my driving is on the street, some spirited. I have not done any hard braking from high speed so I can’t comment on that aspect, but normal braking is fine. I hope someone else will chime in about that. Brake dust is very minimal. I got mine at Kragen so they should be readily available.
[img]http://home.comcast.net/%7Ebsoomann/srsig.jpg[/img]
Bill is offline   Reply With Quote
