Old 06-28-2011   #1
Shoefly
Shoefly's Avatar
Default New zr1
Bought a 1991 zr1 72000 miles at the auction looking for shop in Michigan that works on the zr1 do not want to travel to I'll does anybody have any suggestions
Shoefly is offline   Reply With Quote
Old 06-28-2011   #2
Kevin
Kevin's Avatar
Default Re: New zr1
closest i know of, and arguably the best is Mark Haibek in chicago. Why do you need to take the zr-1 to the shop? if you let us know the problems you're having we can probably help you
Old 06-28-2011   #3
Shoefly
Shoefly's Avatar
Default Re: New zr1
Would like to have it checked over it is over heating in traffic and has small oil leak I do not know much about the older cars I ALSo have 2008 zo6
Old 06-28-2011   #4
Kevin
Kevin's Avatar
Default Re: New zr1
define "overheating" these car's aren't the hugest fans of traffic and tend to run a bit hot till you start moving. where is the oil leak from? front right near the rad?
Old 06-28-2011   #5
Kevin
Kevin's Avatar
Default Re: New zr1
should have said this earlier too:
welcome to the brotherhood. you'll find that we really like to take care of each other here
Old 06-29-2011   #6
Z Factor
Z Factor's Avatar
Smile Re: New zr1
Bought a 1991 zr1
Hello and welcome to the forum.
Old 06-29-2011   #7
Default Re: New zr1
Far as shops go, the LT5 is what makes the ZR-1 primarily what it is, like the LS7 makes the C6 Z06! Less than 1% of the C4s made were ZR-1s, and most of the mechanics at GM dealers have never seen an LT5, let alone work on one. I won't take mine to any of them.
As far as the LT5 goes, the motor was bread for racing and has proven to be bullet proof, unless molested by the unwashed/unfamiliar "mechanic". Most of the R&R stuff on the engine seems to center around the vacuum operated secondary throttle system**, the pre-93 OEM injectors, and somewhere above 40k miles, the starter solenoid contacts need to be replaced or cleaned up at least. The motor has flat tappets, so you're going to want to run an oil with enhanced ZDDP additives; e.g., Amsoil AMO 10W-40, or Mobil 1 for older engines (with ZDDP added). The current API "SM" has less of the zinc and phosphorus in it, requiring motors to have roller tappets (like your LS7).
**If the vacuum secondary system ever gets to be a pain, you can do like many of us have done and eliminate them and install a specially configured "chip". The result is a much simpler system as the engine runs on all 16 injectors all the time which many (like me) prefer!
Here at the Net Registry you'll find very knowledgeable people who can help you with anything you want to know 'bout your find. And, if you need a comprehensive "going over", the world renown ZR-1 Specialist, Marc Haibeck in Addision, IL is closest to you. You don't need no steeenking GM mechanic!!
Welcome to the Brotherhood!
P.
Old 06-29-2011   #8
Default Re: New zr1
Hi, over at the ZR-1 Net Registry site I found this chart for you. It may be of assistance to give you a sense of what the gauges are telling you about coolant & oil temps.
http://zr1netregistry.com/ZR1_faq.htm
Also, not to be a wise guy, but over at the 'mothership' we have an array of How to's, common issues, tips on doing stuff, even a factory TSB data base. I'm not trying to be smart, but when I first got my Z I read thru all of it as it helped me a great deal to get some understanding of the car's quirks and some solutions to them.
Sorry I forgot this is the link to our mothership.
http://zr1netregistry.com/index.htm
Old 06-29-2011   #9
Shoefly
Shoefly's Avatar
Default Re: New zr1
its great to get all this good advice I have had many vettes over the years this is my first older one since I had a 1971 in the late 80's other wize they have all been newer, looking forward to fixing this one up like new, also a menber of the captial city corvette club lansing, mi. and thank you all for the welcome the pleasure is all mine
Old 06-29-2011   #10
Default Re: New zr1
www.zr1specialist.com
He is "the master" and close to you!
