Old 05-17-2011   #1
Mika73
Default Coolant leak, Water pump?
My -90 ZR1 is leaking coolant. It comes a little by little from middle. There is coolant under car and today Low coolant light come on. Course it come from middle and my hoses and radiator are changed years ago. I think maybe its water pump.
Is ZR1 water pump different than others and how much it usually cost?
Need to get this fixed ASAP.
Mika73 is offline   Reply With Quote
Old 05-17-2011   #2
Default Re: Coolant leak, Water pump?
Mika,
Some of the guys have gotten water pumps from NAPA and Corvette Central and used them sucessfully. If I recall correctly, they are in the neighborhood of $200.00. I have not personally used those pumps.
If you are not able to find one that can be shipped to you, I have one (1) OE pump left for sale, but it is more expensive than those i mentioned. Please see the JerrysGaskets.com website if you are interested.
Old 05-17-2011   #3
Scrrem
Scrrem's Avatar
The usual suspect is the pump shaft seal. The pump is ZR-1 specfic and can be pricey depending on where you get it. I chagned mine a year ago and paid about $150.00 for a NOS pump. Check Corvette Central, they have AC Delco pumps for the ZR-1. Make sure it comes with a gasket.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-17-2011   #4
Mika73
150USD doesnt sound bad at all. I have seen 400USD at Ebay etc.
I think pump is orginal and car has now 126 000km.
Old 05-17-2011   #5
Before you replace the pump. Check to make sure all the bolts are tight. The pumps are aluminum and tend to loosen over time. You just never know you might get lucky.
Old 05-17-2011   #6
Mika73
Thank you
I call service first thing tomorrow.
Old 05-17-2011   #7
rhipsher
rhipsher's Avatar
Mika I had to replace my water pump also on my 90. Mine started out as a small leak and toward the end it turned into a raging flood gushing out. Check with a mirror to see if coolant is leaking out of the hole on the underside of the pump.
I got my pump from corvette central with gasket for $199.
I decided to go with Samco hoses. Im still waiting on the hoses. They wont be here till june when the temperature will be 104 degrees 85% humidity. I just can't wait.
Old 05-18-2011   #8
Mika73
I am at Corvette service now. New pump cost 480 euros
Good that they have Pump and I got time so fast. But it's very expensive
I guess it's original part. Don't know how there is so big difference at Prizes.
Old 05-18-2011   #9
Mika73
Total cost 813 euros
Pump, new belt and coolant. I sit there 4 hours
Old 05-18-2011   #10
ittlfly
DAMN! That's a lot of money in anyone's currency.
ittlfly is offline   Reply With Quote
