Old 03-20-2011   #1
| 1990 ZR-1 |
Default WTB: Suspenssion bushnigs and Actuator Cups
I'm specifically looking for two actuator retainer cups that the actuators mount into, and all of the front and rear rubber bussings and washers. Please name your price. If you know any place that sells these, please let me know. I can't seem to find them anywhere.
Thanks -Gary
| 1990 ZR-1 | is offline   Reply With Quote
Old 03-20-2011   #2
Default Re: WTB: Suspenssion bushnigs and Actuator Cups
Can you take a photo of the actuator cup? I'm not sure what you are referring to.
I recommend that you contact Doug or Randy. Doug is a real guru for suspension.
http://dougrippie.com/
Old 03-20-2011   #3
| 1990 ZR-1 |
Hey Jerry, you can see at it this link below.
http://captainzcnc.com/id2.html
I checked out Doug's site, and it looks like he only has the poly bushings listed on his site. I'll call them tomorrow.
I'm not sure who Randy is, sorry. Does he have a website?
Old 03-20-2011   #4
PhillipsLT5
PhillipsLT5's Avatar
also, Vette Brake Products in Fla.
Old 03-20-2011   #5
OK! I was in the bushing mode & never thought about the shocks.
Randy is Doug's son.
If you are looking for stock replacement bushings, ball jts, etc. here's the best place.
http://www.corvetterecycling.com/category_s/23.htm
A complete set of NOS upper & lower control arms, complete with bushings & ball joints already installed for $400.00.
NOS sway bar bushings
Doug Asay is a stand-up guy and has a lot of NOS C4 chassis parts and new radiators.
Old 03-20-2011   #6
Those actuator cups are HTF although any FX-3 equipped car being parted out from MY 1989 - MY 1995 will have them. Most folks wont let them go without having to buy the entire shock as well. Make sure when you buy them you get pics of the top side inside the crown and the underside to make sure the guide dogs are present and the shock shaft rod guide slot has not been enlongated by a previous "Bad install". Just FYI GC
