Old 03-18-2011   #1
Brillo1990
Default Plenum Pull What all do I Need?
OK I plan to pull the plenum and put in new injectors, coil packs, and plug wires. What all do I need to complete the job and what else should I look for while under there? I have been reading the Solutions page but just not sure if I missed anything and need to know where are the (best) places to get everything. I'm coming up with injectors,(RC which ones?) coil packs,(?) wires (on Ebay) and Jerry's gaskets (which set?), is it possible to get this stuff before next weekend? On a side note I am planning on pulling everything again next winter to get the IH, cam covers and plenum powdercoated so if I could get the right set of gaskets for all of it now I would like to. I just want to get the right stuff the first time as not to hold up the show. I tried to reply to my other thread but everytime I log in to do it, it says I entered a wrong password. Thanks guys!
Brillo1990 is offline   Reply With Quote
Old 03-18-2011   #2
mike100
Default Re: Plenum Pull What all do I Need?
the standard thickness plenum gaskets from jerry worked fine for me (twice, lol).
I used my spark plug wires again due to low mileage- I figure I will use them up rather than "collect" them in a zip lock baggie to never be used again.
The best price on new injectors (and rebuilt) are here-
http://fuelinjectorconnection.com/sh...ewCat&catId=68
You might want to get the special primary inj o-rings from Jerry's as well, but the rest of the o-rings come with the new injectors. Honestly, I considered reusing my 20 year old primary seals- they seemed fine.
-probably should spend the extra $2 and get the fuel rail o-ring for the gas line.
-the regular old style green antifreeze from Autozone and several cans of brake cleaner might be a good idea.
Old 03-18-2011   #3
tccrab
tccrab's Avatar
Paul:
How to check fuel injector resistance with plenum in place:
http://zr1specialist.com/HAT%20Web/a...Resistance.htm
How to pull plenum & tools needed:
http://www.zr1.net/forum/showthread.php?t=7614
Gaskets, O Rings, everything you'll need:
http://jerrysgaskets.com/store2/root/
Fuel Injectors in order of cost:
Original GM Multec (big expensive mistake, buy these only if you never plan to drive the car)
RC's
http://www.rceng.com/
Accels
http://www.summitracing.com/parts/ACC-150821/
FIC
http://fuelinjectorconnection.com/sh...&productId=165
Coil Packs & Wires:
TomC
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 03-18-2011   #4
My recommendation:
Injectors,Jon at FIC
http://fuelinjectorconnection.com/sh...&productId=164
Coils
Coils are readily available at local Autozone type stores and have shown to be good replacement quality.
Plug Wires
http://jerrysgaskets.com/store2/root...27d5cc2c2ae641
Gaskets & Seals
I suggest that you buy the following for the work that you want to do.
Phase I (immediate work)
1. http://jerrysgaskets.com/store2/root...&products_id=7
2. http://jerrysgaskets.com/store2/root...roducts_id=384
3. Use 2 of these for the fuel block connection, save the rest for the 2nd phase of your planned work.
http://jerrysgaskets.com/store2/root...roducts_id=388
Phase II (later work)
1. http://jerrysgaskets.com/store2/root...roducts_id=469
2. http://jerrysgaskets.com/store2/root...&products_id=7
3. http://jerrysgaskets.com/store2/root...products_id=10
4. http://jerrysgaskets.com/store2/root...&products_id=9
5. http://jerrysgaskets.com/store2/root...products_id=11
6. http://jerrysgaskets.com/store2/root...products_id=26
7. http://jerrysgaskets.com/store2/root...products_id=30
8. http://jerrysgaskets.com/store2/root...roducts_id=565
9. http://jerrysgaskets.com/store2/root...products_id=24
Contact me if I can be of assistance.
Everything is in stock & shipped USPS Priority Mail. Lower 48 domestic orders usually take 2-3 days from order to delivery.
Old 03-18-2011   #5
Thanks guys.....for the recommendations!
Old 03-18-2011   #6
PhillipsLT5
PhillipsLT5's Avatar
cant' go wrong with jerry
Old 03-19-2011   #7
Brillo1990
Thanks for the info guys, it's much appreciated. Hey Jerry can you PM me a phone number I can call?
Old 03-19-2011   #8
bldavis11
If you haven't pulled the plenum before, take a picture of the vacuum lines as soon as you get it off... You'll thank yourself later. After you've done it once, it really isn't that big of a deal.
I find the most frustrating part is getting the computer cable plugged back in and secured. It just always seems to take me longer to do that than any other step.
Best,
Ben
bldavis11 is offline   Reply With Quote
Old 03-19-2011   #9
Brillo1990
I know Jerry posted this number for the FIC injectors and it says to specify the year of the car but I don't see anywhere on the order to do it. Are all the years the same as far as the injectors go?
Old 03-19-2011   #10
Brillo1990
Ben I plan to take lots of pics while I do the pull just for my own lousy memory.
