Old 03-14-2011   #1
Scrrem
Scrrem's Avatar
Default Crankshaft Position Sensor
I am getting a slow seeping leak starting from my crankshaft position sensor. Is there an O-ring or gasket that can be replaced, any concerns when removing / re-installing?
Thanks
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-14-2011   #2
ittlfly
Default Re: Crankshaft Position Sensor
Here ya go.... I just did the job.
http://www.zr1.net/forum/showthread.php?t=14095
-and-
http://forums.*************.com/c4-z...r-removal.html
I got the O ring at NAPA (as suggested by LGAFF) in a A/C O ring kit. So far it is working just fine. If you need the exact specs for the O ring, drop me a PM as I got them from Jerrys Gaskets if you need them. Jerry doesn't carry them.
(The second URL is on the CF forum)
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 03-14-2011   #3
Scrrem
Scrrem's Avatar
This is the sensor that's leaking....this is the crankshaft position sensor...right?
Ron Davis Radiator
Old 03-14-2011   #4
ittlfly
That picture doesn't look like mine. Crank sensor is on the passenger side, cam positioning sensor is on the drivers side. The cam sensor has flat bottom. That picture really isn't showing that. If that's the dip stick just to the left of the sensor, its the crank sensor you are dealing with.
Old 03-15-2011   #5
Aurora40
Aurora40's Avatar
Rich, that is exactly what the crank sensor looks like, according to the Fuel and Emissions training guide.
Bob Saveland
Former owner of #2517
