Old 03-11-2011   #1
Default Stock IH vs Siamese
Just thought I would show the difference:
Stock(Choke)
(These Siamese are nowhere near finished, need to have ridge taken down, alittle touch up porting, and cleanup with flapwheels and then ported matched to the head)
Old 03-12-2011   #2
Locobob
Default Re: Stock IH vs Siamese
You could cut them into fours, attach sticks and use them for costume party masks
Robert
Old 03-12-2011   #3
Pete
Pete's Avatar
Holy Injector Housings Batman.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-12-2011   #4
IowaZR-1
IowaZR-1's Avatar
Is that a catagory 4 for 5? what will you wind speeds be?
IowaZR-1 is offline   Reply With Quote
Old 03-12-2011   #5
If you are looking to maximize airflow, why leave the "waistline"? Why not blend the ports into one big oval?
Old 03-12-2011   #6
You have to weld the entire IH to make it one big oval, I don't need that much airflow and you would have to do a lot of TIG welding, run risk of warping.
http://www.zr1.net/forum/showthread....siamese&page=2
As noted these are not done , I need a dremel to take down the ridge.
Old 03-12-2011   #7
Pete
I was thinking more Lone Ranger Kemo Sabe!
Old 03-13-2011   #8
Looking alittle better, need to get some flap wheels, might have to clean the center ridge by hand.
Old 03-13-2011   #9
Locobob
Looks good. You need some mini flap wheels and a long mandrel to get the center. I modified a drill bit extension by having the shank turned down to fit in a die grinder - works really well.
Robert
