Old 03-05-2011   #1
lakemeadzmonster
Default I'm looking for an original MEM-CAL
I'm looking to pick up a stock mem-cal for a 1990 model, does anybody have one cheap with the origianal factory program?
[SIGPIC][/SIGPIC]
lakemeadzmonster is offline   Reply With Quote
Old 03-05-2011   #2
Default Re: I'm looking for an original MEM-CAL
http://www.zr1.net/forum/showthread....ighlight=Eprom
$155
Old 03-05-2011   #3
RICHARD TILL
I`ve got a stock eprom that i removed from my 90 model in 2000. The only problem with it was that it took too long to come down in idle speed. Would it be of any use to you?
Old 03-05-2011   #4
lakemeadzmonster
Yes my old one did that to. I would like to have it. I don't have my stock program and would like to see the differences when compared to the one I have.
[SIGPIC][/SIGPIC]
Old 03-05-2011   #5
Aurora40
Aurora40's Avatar
Is your actual PROM bad? Or you just want a stock program on it? I imagine any of the ZR-1 folks like Marc H, etc, could just burn you the stock baseline program to your current PROM.
Edit: also you may want to mention the year of your car.
Bob Saveland
Former owner of #2517
Old 03-08-2011   #6
Aurora40
Aurora40's Avatar
So did you get a PROM, or do you still need one?
Bob Saveland
Old 03-09-2011   #7
lakemeadzmonster
I was wanting to try a stock program and compare it to my current setup, I only have one. I still need one or borrow it. Mine is a DRM level one and seems fine but I would like to try the stock set up and maybe just tune in my current program?
[SIGPIC][/SIGPIC]
Old 03-09-2011   #8
ZR1@gmx.com
My programmed chip mounted to my stock chip... could yours be like that?
Fun 91 #303
ZR1@gmx.com is offline   Reply With Quote
Old 03-09-2011   #9
If you want, I can burn you a prom with the stock 90 program on it (even dropping the idle if you want). You would need a Moates daughter board to piggyback it onto. But then you would be able to remove it and run the chip you have in there and compare. You can PM me if interested.
Old 03-09-2011   #10
Aurora40
Aurora40's Avatar
I have a '90 PROM "AYBK", which was the latest version for 1990. $100
I also have an "AUAH" 1990 PROM which was the original in my car. $75
I think these prices are fair given how the availability of the OEM style PROM has become. If you are interested, let me know.
Bob Saveland
