Old 02-19-2011   #1
bldavis11
Question Earl's SS Brake Lines
I'm looking for SS brake lines, but can't seem to find anyone selling the all-popular Earl's.
What supplier do you guys go through?
Also, what about the Russell brand of hoses/lines?
Ben
bldavis11 is offline   Reply With Quote
Old 02-19-2011   #2
Default Re: Earl's SS Brake Lines
Ben, It's been a long time but I thought I bought mine from Jegs.com. They are not listed under ZR-1, but rather I found them by looking up s/s lines for a standard C4.
I am reasonably sure that DRM also has them in their C4 Brakes Section.
http://dougrippie.com/?cat=21 this is for DRM.
Old 02-19-2011   #3
bldavis11
Appreciate it Tom!
Old 02-19-2011   #4
I bought Russell lines the last time from Summit. And yes they were LT-1 lines that will fit and work.
Old 02-19-2011   #5
Originally Posted by bldavis11 View Post
Appreciate it Tom!
Just in case you do not buy the ones from Summit or Jegs and get the ones from DRM.....I just remembered this..... I had to buy shorter bolts from Jegs to make the connection. The stock banjo bolts are too long to use with the Goodrich(?) lines that DRM has.
Old 02-19-2011   #6
gbmidyear66
Ben
I'm in the market myself. Amazon has both Earl's and Russel lines - with free shipping I believe.
gbmidyear66 is offline   Reply With Quote
Old 02-19-2011   #7
gbrtng
gbrtng's Avatar
Foggy memory from 15 years ago - I got a good set from DRM after returning a set to MAD which I couldn't get to seal at the caliper(s). The MAD ones were Russells.
Old 02-20-2011   #8
bldavis11
Originally Posted by gbmidyear66 View Post
Ben
I didn't see the Earl's on Amazon. I'll have to look again. Thanks! I've got the Amazon Prime deal as well, so it's 2-day shipping with no charge... not all that bad actually.
Old 02-20-2011   #9
gbmidyear66
Ben, here you go....
http://www.amazon.com/Earls-28A050ER...8242246&sr=8-1
I'm still deciding what I want to buy for a pressure bleeder, so haven't ordered lines yet - what are you using?
Glenn
Old 02-21-2011   #10
bldavis11
Glenn,
I'm really considering the Speed Bleeders... not a pressure bleeder per se. Do you have any experience with them?
http://www.speedbleeder.com/
