02-12-2011 | #1 |
368 parts
What all do I need for a 368...
LA Sleeve/4": $1200 JE Pistons: Part #? Rods: Part/Manufacturer???? Cost of Hone the Block????
02-13-2011 | #2 |
Re: 368 parts
Why?
you can use stock rods if you want. Pete
02-13-2011 | #3 |
Re: 368 parts
So I just need Pistons/Sleeves and honing?
02-13-2011 | #4 |
Re: 368 parts
02-13-2011 | #5 |
Re: 368 parts
Lee I can hook you up with a set of 368 JE pistons for stock rods and the crank that they were run on (balanced for 368 ). You should also ask me about the 380ci motor option :-)
02-13-2011 | #6 |
Re: 368 parts
Let me know your thoughts on price....thanks
02-13-2011 | #7 |
Re: 368 parts
02-13-2011 | #8 |
Re: 368 parts
I just have a bunch of stuff, still...
As far as the 377/383ci goes it uses the stock crank. Doing a 368 and not jumping up to the 377/383 is nuts. The cost is under $400. The added torque on the motor will jump from 370's to 420's. Lets put it this way, you spend $15.5 to get a 368 and you left up 50rwtq on table for only $400. The build cost the same ( - the $400). King Bearing makes the special rod bearings that are 1 piece, this is a big plus. This stops the need to buy aftermarket rods ( more money not needed at this power level ). |
02-13-2011 | #9 |
Re: 368 parts
are you talking about offset grinding the crank?
02-13-2011 | #10 | |
Re: 368 parts
Ah motor porn!!!! Im going the 380 route with Kevins help already. Best bang for the buck on a budget stroker. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-13-2011 at 11:48 PM. |
