Old 02-06-2011   #1
5bear4
Default Injector electric connector gaskets
I am in the process of changing my injectors and noticed i am short some of the gaskets that go inside the electrical connector. I have checked the internet for new ones but I am coming up empty. Does anyone know where I can get some or are they even important?
5bear4 is offline   Reply With Quote
Old 02-06-2011   #2
Default Re: Injector electric connector gaskets
Check with Jerry
www.jerrysgaskets.com
Old 02-06-2011   #3
VetteMed
I've run without them, with no apparent ill effects, but I suppose they make for a more weathertight seal. Probably not an issue for most driving conditions but I guess it's better safe than sorry.
Old 02-07-2011   #4
How many do you need?
Old 02-07-2011   #5
bobbyhi
bobbyhi's Avatar
I lost a couple when I did mine and just made new ones out of gasketing material. Easy fix..............
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
