Old 01-31-2011   #1
tomcat
tomcat's Avatar
Default ZF transmission fluid.
Players' getting ready to change Transmission & rear end Fluid. What fluids should I use?
Manfred E..........
91 #906
http://pnwzr1.net
tomcat is offline   Reply With Quote
Old 01-31-2011   #2
Default Re: ZF transmission fluid.
zfdoc says Castrol TWS 10w-60 full synthetic. It can be bought at the local BMW dealer only & it comes in Liters only. You need 2.2 liters to do the change.
I bought it from this guy the last time as the local BMW dealer is not easy for me to get to.
http://www.velocitymotorcars.com/castrol.html
btw, it's motor oil for an M5.
The rear gear I used Mobil 75w-90 full synthetic plus one bottle of GM posi additive. If you use GM gear oil then use two bottles of posi fluid additive. Or you can use Amsoil sever duty fluid plus one of their posi additive bottles
Old 02-01-2011   #3
AT T 2D
AT T 2D's Avatar
Should the transmission & rear end fluids be changed based on mileage only or should they be changed after a certain number of years as well? I have a 10k mile '94 and my Chevy dealer said not to worry about it.
AT T 2D is offline   Reply With Quote
Old 02-01-2011   #4
Jagdpanzer
Jagdpanzer's Avatar
After being in there for 17 years I would change both just for the sake of peace of mind.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-01-2011   #5
ittlfly
Yep, those dealers are all experts. That is probably the same dealer that told Custer, "one last stand and you can go home"!
ittlfly is offline   Reply With Quote
Old 02-01-2011   #6
I would just say use this link and read the section on the page about the results of Mr. Boudreau's oil test.
http://zfdoc.com/faq.htm
You can make an educated determination once you have the necessary information. I used his research to determine what my change intervals would be going forward and my car was a one owner car with 7400 miles on it when I bought it back in 12/04.
