Old 01-30-2011   #1
Default Cam cover vent material
Getting ready to put cam covers on. What material do you use for the vent tubes. It looks to be a "scotch-brite" material.
Old 01-30-2011   #2
Default Re: Cam cover vent material
https://www.jerrysgaskets.com/filter...t-2-90-95-1b4/
Old 01-30-2011   #3
VetteMed
I used scotch-brite, the green stuff. Folded it up on itself a few times and secured with the stock wire.
Old 01-30-2011   #4
ZR1@gmx.com
I have some that is about an inch thick, from a floor buffer If any one wants some shoot me your address and I will send you some to cut and use,
I have White, green, red and black. The order is fine to course.
ZR1@gmx.com
ZR1@gmx.com is offline   Reply With Quote
Old 01-31-2011   #5
flyin ryan
flyin ryan's Avatar
Post Pack it in...
Layer the Scotch-brite & pack in as much as you can. Will breath fine & will help keep oil in the engine.
Old 06-09-2014   #6
UPDATE:
Our preferred mist extraction filter.
Old 06-09-2014   #7
PhillipsLT5
PhillipsLT5's Avatar
Jerry just keeps the parts coming & our cars going
Old 06-09-2014   #8
ALZR1
I use copper brillo/scubber material you can pick it up anywhere,pack as much as you can.
Al.
ALZR1 is offline   Reply With Quote
Old 06-09-2014   #9
All,
This is an old thread. Ultimately I replaced the Scotchbrite I originally installed w foam material from Marc Haibeck. Even replacing it in one cam cover was enough to eliminate a persistent oil leak I had when winding the motor beyond 5K.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-10-2014   #10
All,
I second the motion
Haibeck Cam Cover Filters
