01-26-2011 | #1 |
WHeels and Tires, need tech and opinion
I would love, or at lest I think I would like a new style ZR1 wheel to replace my 91 wheels.... I just like the spyder look.... but I cannot seem to find the corret size offset... anyone know where I would go about getting the correct 18" wheels with offsets and tires???
thx in advance... |
01-27-2011 | #2 |
Re: WHeels and Tires, need tech and opinion
Hi & welcome to our corner of the asylum!
As an "off the shelf" product we are limited in our choices even at our OE 17" size, at larger diameters I have never seen anything that would not need a spacer to adjust the new wheel to our required rear offset. I'm sure that there is a wheel company somewhere that would be willing to make wheels in our offsets as a special order item, but I've never looked into how much that would cost....I'm sure it's more than I could afford anyway! Tom
01-27-2011 | #3 | |
A spacer is going to be be necessary for correct fitment. The rear Z06 wheels I had on my car were backed up with an 18mm spacer using longer GM racing studs. As for the fronts, the 40mm offset worked out ok visually but I believe you can find aftermarket 18" wheels with an offset closer to the stock 59mm offset on our ZR-1s. BTW, =Jeff= ps'd the new ZR1 wheels on my car and I thought they were a bit too busy bs the more simple ( and elegant) Z06 split spoke. These wheels have more of a Ferrari look to them IMO. |
01-27-2011 | #4 | |
01-27-2011 | #5 |
Ok, thanks for everyones time.... so far no luck... so I agree after viewing the photoshop, the new ZR1 spyder is too busy... but I do like the more simple chrome style C5 style Z06...... can I buy a set of those somewhere?
01-27-2011 | #6 |
The ones in my pics were not C5s, they are C6Z. Just want to make sure you're looking for the ones you really want.
01-27-2011 | #7 |
can someone tell me what zr-1/zr1 spyder we're talking about here?
01-27-2011 | #8 |
Dominic (XfierZ51) had C6ZO6 wheels on his green car and it looked great.
01-27-2011 | #9 | |
Frank, These z06 wheels should look dynamite on the Black Rose car. Have you ever done yours? Last edited by XfireZ51; 01-27-2011 at 07:00 PM. |
01-27-2011 | #10 |
