Old 01-23-2011   #1
kenehresman
Default 91, No Power Mirror or Cruise and Blown Fuse
Repalced and still no worky.... blew again... anyone have any ideas? Are these on the same circuit?
kenehresman is offline   Reply With Quote
Old 01-24-2011   #2
kenehresman
Default Re: 91, No Power Mirror or Cruise and Blown Fuse
bump... anyone have a diagram for this circuit?
Old 01-25-2011   #3
does the fuse blow when installed? or when you go to use the mirror controls?
Old 01-25-2011   #4
kenehresman
The fuse does not blow when installed, I am confirming exactly when it does blow.... but I'm pretty sure it is when I try to use the switch.... for either mirror....
Old 01-25-2011   #5
Is the Fuse the right AMP for the job? Too low it will blow upon use. Did you verify in the Drivers book what amp should be in there
Old 01-25-2011   #6
kenehresman
Book shows 10A, I stepped up to 15 then 20 and get the same results.... so I know it isn't a current size issue....
Old 01-25-2011   #7
does it blow when you try to use the Cruise as well?
Old 01-25-2011   #8
Well that figures I just hate electrical issues and its never anything easy. A Bad switch or a pinched wire can easily cause this. Go through that manual and find every system that fuse ties too. Start with the mirror switch and harness. Its sucks but something is obviously grounding out the circuit cause that fuse to blow.
Old 01-25-2011   #9
Valid question
Old 01-26-2011   #10
gbrtng
gbrtng's Avatar
Which fuse? Don't try a higher current fuse - you'll only make things worse because there is a dead short somewhere.
