Old 01-20-2006   #1
Default T-stat question
Hi Guys, I finally got the correct 1825-M spec coolant from GM so I'm going to get rid of the stuff the dealer put in my car. I figure on replacing the thermostat as I don't know how old it is.
My Q is if you are using a stock EPROM is a 180 stat worth getting? I'm not trying to be funny. It's just that the programing in the prom turns the fans on and off at some fairly hi temps. Will that programing work against the 180 stat? Will the 180 help in traffic or am I mis-informed??
I cleaned out my rad & condensor & oil cooler and installed a screen to stop stuff from getting back up in the cooling fins. I know I have a GM stat, 195*, in the system now. The cooling system responds when both fans are turned on and the temps come down. The temps are not a problem if the car is on the road but in slow traffic it gets up there and kind of stays at what looks like 200* more or less.
Thanks for any advice you want to share!
Old 01-20-2006   #2
Default Re: T-stat question
I still have the stock t-stat but a custom chip that turns on both of the fans @ 205 off @ 200...
Steve
Old 01-20-2006   #3
Bill
Bill's Avatar
Make absolutely sure that it is the right style thermostat with the correct bypass valve. I got the wrong one and it cost me 2 radiators.
Bill is offline   Reply With Quote
Old 01-21-2006   #4
Thanks to Steve and Bill!
Yes Bill I remember following the saga of the t-stat that was boxed wrong & caused you to loose the rad.! That stopped me at the time from scratching where it didn't itch! I had my local dealer do a flush & refil on my car back in Nov.05 and they used the wrong coolant so I figure if I use the the correct coolant I'm gonna open the t-stat housing to flush it with the motor runing. Having said that I fugured I should swap out the t-stat since I don't know how old it is, and that I'll be there anyway.
Steve, I get caught in traffic a good bit on some cruises and some cruises we go into NYC so I was looking for an edge on the engine temps. I can live with the stock T-stat as even though the coolant temp gets up there the oil temp stays below 1/2 way on the gauge even if I get caught for awhile in B to B stuff. Both come right down once airflow is re-established, man I'm so glad I clean that stuff & put the screen in!
Maybe I'll get a stocker and a NAPA 180 and do my own road test!
Thanks for the input guys!
Old 01-23-2006   #5
The temperature gauges are very non-linear. The 90 only had values at the end point while later cars had additional divisions and values. The mid-point of the needle travel on your 90 does not equal halfway between the 100 and 260 values on the gauge. The mid-point on the oil temperature gauge equals 220 deg and the mid-point on the water temperature gauge equals 210 deg. "The Legend" magazine from the ZR-1 registry had an article that included a table and diagram showing the actual values. I copied the table/diagram and keep a copy in my console as a reference. I have seen the same table on the internet but I don't remember where, I thought it was on this site but I couldn't find it recently.
Tom is offline   Reply With Quote
Old 01-24-2006   #6
Tom how did you know that I was thinking about that? Thanks man!
Doing the math it didn't make sense to me that the gauge reading had a linear progression! It just seemed too low of a temp reading, by the math that is. I guess it's worth a try with a 180 just to see if in traffic I get a lower overall coolant temp...even a little would make me feel better. I feel so much better when I see the needle 1/2 way instead of 3/4 or more up the gauge face! It only happens in traffic without the climate control "on", if I use the CC the other fan kicks in and brings the temp down a bit. I think it's a perception thing with me...I hate to see a temp gauge up so high in traffic and my first instinct is to turn off the CC. My 72 LT-1 A/C coupe would never allow me to stay in B to B traffic with the A/C on! Guess I gotta get used to this new hi-tech corvette.
thank you for the info!
Old 01-25-2006   #7
Hotrod
FYI: You can use the a/c display to read engine coolant temp.
Hotrod is offline   Reply With Quote
Old 01-25-2006   #8
Thank you Hotrod! I didn't know that.
I guess I would find that info in the Helm manual in the "Drivability & diagnostic" section? I know I don't remember seeing it in either "owner's manual".
Old 01-25-2006   #9
Bill
Bill's Avatar
Here is the procedure:
1) press the fan up & down buttons simultaneously until 00 appears in the AC display
2) press and release the fan up button until 16 appears in the AC display
3) press the fan auto button
4) the AC display will show coolant temp in degrees C.
Old 01-25-2006   #10
haber rj
Hello Bill this information is great, I had no idea (along with a lot more I am sure) that we could do this. This is what makes this forum such a great place, nice people with a lot of information to share with members like myself who have a lot to learn.
Cheers
haber rj is offline   Reply With Quote
