01-04-2011 | #1 |
Opened my shipment from Jerry today..
I have never taken one of these apart, and how he individually wrapped, and labeled every single bolt, screw, bracket, etc I could put it together with no problem lol.
Hats off Jerry, it is always nice to see such attention to detail! |
01-04-2011 | #2 |
Re: Opened my shipment from Jerry today..
close, in bags no less lol
Gasket, coolant outlet pipe (1 pair) 1 Gasket, cylinder case vent cover 1 Gasket, engine front cover 1 Gasket, oil pan 1 Gasket, oil pump access cover 1 Gasket, water pump 1 Seal, engine front cover 1 Seal, timing chain access bolt (set of 2) 1 Seal Set, oil pump o-ring (set of 4 seals) 0 Seal, PCV tube (set of 2) 1 Seal, timing chain tensioner (set of 2) 1 Seal, oil pan drain plug 1 PARTS Bolt, Camshaft Sprocket [0060-1] 4 Pulley, Water Pump [0061-1] 1 Bolt, Water Pump Pulley [0061-1] 4 Bolt, Lower Alternator, M10 [0061-1] 1 Bracket, Lower Alternator [0061-1] 1 Alternator, used [0061-1] 1 Bracket, Top Alternator [0061-1] 1 Bolt, Top Alternator [0061-1] 1 Shield, Alternator Fan [0061-1] 1 Bracket, Rear Alternator [0061-1] 1 Compressor, A/C [0061-1] 1 Bolt, A/C Compressor [0061-1] 3 Bracket, Power Steering [0061-1] 1 Pump, Power Steering [0061-1] 1 Pulley, Power Steering [0061-1] 1 Reservoir, Power Steering [0061-1] 1 Hose, Low Pressure Return [0061-1] 1 Hose, High Pressure [0061-1] 1 Bolt, P/S Bracket to Cyl Head [0061-1] 3 Bolt, P/S Pump to Bracket [0061-1] 3 Tensioner, Serpentine Belt [0061-1] 1 Bolt, Belt Tensioner [0061-1] 1 Belt, Serpentine [0061-1] (purchase locally) 0 Sensor, Cam Position [0064-1] 1 Shield, Cam Position Sensor [0064-1] 1 Bolt, Cam Position Sensor [0064-1] 1 Starter [0065-2] 1 Bolt, Starter [0065-2] 2 Coil Pack Assy (not required) 0 Hose, Crankcase PCV, LH [0065-2] 1 Hose, Crankcase PCV, RH [0065-2] 1 Clamp, Crankcase PCV Hose [0065-2] 4 Chain, Secondary, LH 1 Facing, Sec Tmng Chain, LH, Fixed 1 Facing, Sec Tmng Chain, LH, Pivot 1 Facing, Sec Tmng Chain, LH, Top 1 Chain, Secondary, RH 1 Facing, Sec Tmng Chain, RH, Fixed 1 Facing, Sec Tmng Chain, RH, Pivot 1 Facing, Sec Tmng Chain, RH, Top 1 Chain, Primary 1 Facing Primary Timing Chain 1 |
01-04-2011 | #3 |
Yeap,
Jerry,is the man. He packs them good. He ships them fast. He's not from this world. He must be Superman. Pete
01-05-2011 | #4 | |
If only all businesses were conducted the way Jerry runs his...
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
