Old 12-31-2010   #1
todesengel
Default oil temp
For you guys who track your cars, with the stock cooler setup, what does your oil temp average on hot summer days?
todesengel is offline   Reply With Quote
Old 12-31-2010   #2
gbrtng
gbrtng's Avatar
Default Re: oil temp
I'm usually too busy to pay attention, but I've never run it so hard as to enter the limp home mode which happens at 260 degrees (I think). If you run synthetic oil, 300 degrees is no problem.
Old 02-03-2011   #3
sammy
the oil pressure in my 92 even in the 105deg temp is allways between 186-195 .the 186 is when on the freeway and the 195 is sitting in traffic. i believe that the oil cooler opens at 180 deg.
Old 02-05-2011   #4
todesengel
thanks guys
Old 02-05-2011   #5
I knew there was a thread about oil temps somewhere here. Check this out as it may be of some help.
http://www.zr1.net/forum/showthread.php?t=7320
Old 02-05-2011   #6
todesengel
Thanks again Tom, looks like I need to use the search function.
