12-08-2010 | #1 |
WMD - Sunday, December 12th, in Westminster, MD
Everyone is invited to my garage in Westminster, Maryland on Sunday, the 12th of December for a Westminster Maintenance Day.
We are planning on doing rear suspension and differential work on my 1994 ZR-1. Then, if we have time, replace the differential on David's 1994. (gear ratio change). Plus what ever anyone else needs to work on. We will start about 9 AM. Call or post here if you need directions. Jim 443-244-2347
12-08-2010 | #2 |
Re: WMD - Sunday, December 12th, in Westminster, MD
I'm in! (I may bring a set of injectors along.)
90 ZR-1 #0951 Bright Red (sold) 06 Z51 MN6 Velocity Yellow (sold) 2023 C-8 Z51 ELB WAZOO Member |
12-08-2010 | #3 |
12-08-2010 | #4 |
It's actually supposed to warm up (a bit) for the weekend, so that'll be good. I'll keep the WMD in mind!
12-09-2010 | #5 |
I will be stocking up on propane so the heater will be in full blast mode. Can you say toasty?
As an added bonus, I will try to get a coffee maker operating out in the garage and I will be serving hot spiced cidar from our local orchard. OH yea, we may also work on some ZR-1's!! Jim
12-10-2010 | #6 |
Ok, so I'm curious... Swapping the differential on David's car? He already has 4.10's, what are you swapping them to?
Also, just a suggestion, if you can, park a couple of ZR-1's that have been driven there in the garage. A fully warmed up LT5 is about the best garage heater you can imagine, at least to get the warm-up started. That's generally what I try to do in the winter, work on the car after I've driven the other in the garage. It warms the place up substantially faster than any space heaters do.
12-10-2010 | #7 |
I beleive he is going back to stock gearing. You know him, he changes stuff on his car as much as he changes his underwear.
12-10-2010 | #8 | |
12-10-2010 | #9 | |
Rich
12-10-2010 | #10 |
Hey Rich, what sealant did you use to seal the differential to the bat wing?
Thanks, Jim |
