09-12-2010 | #1 |
Headlight
Need to replace halogen bulb. How do you remove the cover ?
Vince
vinsZR-1 |
09-12-2010 | #2 |
Re: Headlight
There should be some small phillips-head screws retaining the cover. I think there's 4 of them - one on each side, that require manually cranking the headlight halfway up to see, and the other two, I don't recall where they are but they are not hidden... I may be mistaken, there may be just the 2 on the sides and that's all... the key is to crank that light halfway up, manually, with the black knob on the headlight motor.
