08-31-2010 | #1 |
injector "cleaning"?
With injectors that seem to work ok, and have correct resistance readings, is there a solution/solvent that they can be soaked in to "clean" out the carbon or other deposits? Something that cleans, but does not harm the coil/etc.?
09-02-2010 | #2 |
Re: injector "cleaning"?
BG products delivered to the fuel rail directly via canister with fuses removed for fuel pumps. If you have early 90's z, I would leave them alone.
