Old 08-23-2010   #1
DTZ ZR1
Default Overheating
When in stop and go traffic coolant temp gets up to 250 degrees. Once I get moving it drops down to normal temps. I have changed the thermostat. I am thinking that it is the coolant temp sensor for the ECM. I figured that if it is that that I would also change the sensor for the gauage. Question is are they the same type of sensors and also am I on the right track with my troubleshooting? Thanks for any advice.
DTZ ZR1 is offline   Reply With Quote
Old 08-24-2010   #2
Default Re: Overheating
Originally Posted by DTZ ZR1 View Post
When in stop and go traffic coolant temp gets up to 250 degrees. Once I get moving it drops down to normal temps. I have changed the thermostat. I am thinking that it is the coolant temp sensor for the ECM. I figured that if it is that that I would also change the sensor for the gauge. Question is are they the same type of sensors and also am I on the right track with my troubleshooting? Thanks for any advice.
You may want to put a scan tool on it and see if the gauge reading matches the CTS signal to the ECM
Old 08-24-2010   #3
Pete
Pete's Avatar
Do not drive it at those temps you could blow a head gasket,don't ask me how i know.
If she starts to get hot even in stoped traffic rev RPM's to about 2k she will cool down a bit,it will pump more water thru the motor.
I would check make sure both fans are working, also check/clean front of radiator
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-25-2010   #4
Kb7tif
Install a switch to turn on BOTH fans when you want, or burn a chip to turn fans on at 190.
Kb7tif is offline   Reply With Quote
Old 08-25-2010   #5
Its prob time for a radiator replacement. You might be able to remove it clear out all the leaves and debries and get all the sand and silt out from between the fins. But this would be my guess since I been down this road with 3 C4s already. A regualr GM replacement radiator solved the problem each time
Old 08-28-2010   #6
batchman
Your radiator fan is not running. General suggestions that can help if you find yourself in this situation:
- turn on max a/c, most cars this forces fan on if it's operable
If that fails to drop temp within 30 sec or so,
- turn on max heat
This uses the heater core as a cooler. Yes the cabin will be unbearable but it will drop the engine temp.
Good luck,
- Jeff
Old 08-29-2010   #7
L8apex
L8apex's Avatar
Here is what it is likely to look like when you pull the radiator shroud. I could not believe how much cooler my water and oil temps were once this was cleaned out!
Uploaded with ImageShack.us
L8apex is offline   Reply With Quote
Old 08-29-2010   #8
Hammer
Hammer's Avatar
Talking Re: Overheating
Just went through this. The left fan motor was not working. Runs fine now.
Old 08-29-2010   #9
rhipsher
rhipsher's Avatar
I think I see Jimmy Hoffa's wallet in there.
Old 08-30-2010   #10
Coupe89
Thats what mine looked like yesterday Also has a skiddle wrapper and 3 to 4 plastic wrappers....
Coupe89 is offline   Reply With Quote
