08-19-2010 | #1 |
Belt Size: AC Delete
After trying a few belts looks like 69.5 to 70" 6 rib is what you need.
08-20-2010 | #2 |
Re: Belt Size: AC Delete
nice info . do you have to take the compressor of to do the deleet?
08-20-2010 | #3 |
I would not think so, I am dropping weight on the car too
08-21-2010 | #4 |
I went with a 67". Haven't tried it yet, so we'll see.
08-21-2010 | #5 |
I tried 67, 68 1/8.....no go.....used a belt for O"REilly Auto parts K060695, which is 70". Anything over 69 would probably work.
Engine should fire in the next week or so, I will post if the belt works Pete thought it was 66-67, but he might have UD pulleys
08-21-2010 | #6 | |
Lee,i mixed up the #'s since i used the no A/C belt for a short period till i had to use a 57" without water pump that's why i had the number 7 in mind but your right it's 69.5" with no A/C and 57' with no A/C and no water pump. A little secret about belt part #'s K060695 the first 6 means ribs the 695 means 69.5 inches some might have these #'s in different order but mean the same. Pete
08-21-2010 | #7 |
anybody wanna buy a 67" belt.
08-21-2010 | #8 |
I might have my old 69 belt if you want it.
Pete
08-08-2014 | #9 |
I just got a NAPA 60690 (believe that's Gates) 69" to finish my A/C delete (with stock other pullies), after not finding this thread and working my way through each part number from 67.2 on up.
I should have measured it but since it was my 5th try and I have an event Sunday I didn't take the time LOL. I did find the sticker's advice about coming from the back of the water pump is a little tougher to do with no AC as there's very little distance from the PS to the WP. And with a camber brace it's even more fun but it did work, pretty much as it should. Seems to put the tensioner about 2/3rds of its' sweep. I almost got the 68.5 (60685) to work but would have had to pin the tensioner or find a third hand. I'm almost anal enough to try a paint dot on a pulley and the belt to make sure it's not a harmonic length but not quite LOL! Cheerio, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
08-09-2014 | #10 |
I believe that belts get particularly complicated because construction is actually 'metric' but they get part numbered in generally an 'approximate' SAE dimension.
Goodyear I believe still puts both on the sleeve. Here's the Gatorback references: http://www.goodyearep.com/productsdetail.aspx?id=3128 A 69" sales spec is actually closer to 69.1 - it matters sometimes. |
