Old 08-07-2010   #1
Default SW header/dipstick brackets: Correction
4 more went out the door today to the WAZOO. This keeps up, I'm gonna have to get some proper tooling!
For those that bought um...
The small ear is held by the fwd upper bolt of #4 exhaust port. The stove bolt comes inside out with the nut facing the fender and the shoulder of the stove bolt "locking" the dipstick tab in place when tightened.
I'm not in the bitness of making them, but glad to do so if anyone needs one. (If the market was bigger, then mebby. However......
My technique is improving which makes for more uniform appearance, if not functionality. Anyway, uz guys, use 'em in good health!
Oh! One other thing...After you get it installed (or even before), you might need to "tweak" the tube just enough soze not to rest against the #4 exhaust tube - a 1/4" or 6mm should do it.
Still have some detailing to do, as you can see...
P.
Old 08-07-2010   #2
Default Re: SW header/dipstick brackets
Thanks Paul. Going to install a set Aug 21st for one of our members.
Thanks!!!!!!!!!
